D17 clutch rod falls out of bell housing
WD45 Aaron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Topic: D17 clutch rod falls out of bell housing
    Posted: 05 Jan 2026 at 7:26am
Happy New Year all,
 I have newly acquired D17 gas. It's a franken tractor built from various parts. The operating rod from the clutch pedal falls out of the bell housing. What is supposed to retain it into the clutch fork? More importantly, can I fix it without splitting?
Thanks!
Aaron
Machinery rescue for all things rusty or broken. Current residents include 2-1/2 WD45s, Oliver Row 77 gas, Farmall super C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 7:57am
The rod threads into end of clutch fork, if you're lucky, try lining it up and threading it in. No idea how many turns into fork - that is what controls clutch pedal travel. Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 7:59am
Hmmmm. I wonder if the threads are stripped off the rod. I saw a hex, but when I quickly looked at it it appeared smooth. I am going to have to take a closer look.
Hopefully the threads are good in the fork. Fingers crossed.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 8:55am
Or. The rod broke and the threads are in the fork yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 12:47pm
Seems as tho this happens once in a while. The threaded clutch rod is 1/2" NF thread. The nut inside the bellhousing surely has damaged/missing threads. To avoid having to split the tractor you need to make a smart repair. Whack off the end of the clutch rod approx 1 1/2" inches. Whack off the threaded end of a 1/2" NF bolt and weld it onto the whacked off clutch rod. Smear a bunch of red or green loctite on the threads and install into the bellhousing, making at least TEN good turns into the nut. Twenty turns is one inch. Let the Loctite cure overnite and you should be fixed until it's time for a clutch job. How far you screw the rod into the clutch yoke nut, only positions where the clutch pedal will wind up. It has NOTHING to do with actual clutch adjustment. So, with that in mind try and pre-figure where you'd like things to turn out when done. Cutting off the end of a bolt would give you 1 1/2" max threads. So, maybe you want to cut that much off the clutch rod itself ?? it's up to you. New threads on your clutch rod should help make up for rough threads inside. And loctite should lock them together for as long as they need to be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 1:50pm
This is great info! Thank you! My next question was going to be what thread it is. I have a full machine shop at my disposal. With your description this should be an easy one. Fingers crossed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 1:51pm
the FURTHER it screws into the nut, the better... Chances are there are 3-4 damaged threads on the nut, and an inch inside the threads are OK...
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 7:44pm
Ok, we're getting somewhere. It appears that the threads on the rod are fine, just full of gunk and need to be cleaned. The nut on the fork appears stripped out. I might look at work and see if we have a helicoil kit for 1/2-20. Otherwise, I can make a threaded insert on a lathe and fit it into the nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 8:38pm
There's been a problem going on there for a long time. First off, that looks like 1/2" NC threads not NF threads. Second, someone has put a stop nut on the rod to keep the rod from pushing thru the internal nut, which is worn out. Good luck with whatever you try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2026 at 8:55pm
Likely rethreaded the original fine threaded hole to coarse thread.  starts you out at a disadvantage, as you get a sloppy mess, when you do it that way...Thumbs Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 8:24am
You got 10 threads on the roughly 1/2 inch sticking past the nut. That is fine thread on the rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 11:40am
I grabbed a coarse as well as fine thread bolt with nut from the shop. In my picture of the clutch rod I count 10 threads past the nut (not counting the chamfer lead). I threaded each nut out the same number of threads. I agree, it appears to be fine thread.
Edited by WD45 Aaron - 06 Jan 2026 at 12:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 8:42pm
So, are we fixed ???????
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 4:57am
I am hoping to get some time Saturday afternoon to give it a shot. I will report back.
