D15 Steering shaft
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D15 Steering shaft
    Posted: 29 Dec 2025 at 9:40pm
What is the best way to separate the U joint from the upper steering shaft.  I am assuming it is a solid pin that is pressed in.  Am I correct?  You can also tell that the steering shaft has slid down a lot.  I think the snap ring groove has worn out so the snap ring no longer stays in place.  Any way to fix it aside from getting a better shaft?
Also, can someone provide the part numbers for the D15 Diesel power steering lines?  The AGCO parts book website shows the early D17 gas lines for some reason.
Many thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 10:46pm
Grind off the pin on one side so it will drive out using the proper sized punch and a 3 lb hammer while someone else holds the steering wheel from turning. Turn the steering wheel hard until the Ujoint lets it spin free while pulling up on it. Find a stack of machine washers to create the distance you want and place them inside the bottom of the steering wheel. Grease/oil the shaft while reinstalling. Use a 3/8" bolt and lock nut to replace the Ujoints pin of the exact length. You are fixed. You want a new shaft and snap ring?? This is a better permanent fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 8:01am
Problem solved.  Had my local fab shop weld up the shaft around the snap ring groove and cut a new groove.  Snap ring fits good and tight now.  The old snap ring was actually sitting 1/2" higher on the shaft when I removed the steering wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 8:11am
Whenever I've dealt with this problem, is was a working tractor yet and a new steering wheel wasn't going to happen. So, you work with what you've got to work with.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 9:15am
Nice fix! I used washers on my D 15 like the good Dr suggested. Would be nice to have a friendly machine shop though. Local guys don't mess with small stuff much
