Hyd Shift on 2000 Monoframe Plow
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Hyd Shift on 2000 Monoframe Plow
    Posted: 16 Nov 2010 at 4:54pm
I am going to look at a 2000 Monoframe with hyd. side shift on the hitch.  If you right tractor wheel is set properly, can this work as a 'vari-width'?  Thanks!
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 5:03pm
I would say NO, the only thing you would change is the width of the first bottom. All the other ones would not change
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 5:11pm
I have a green semi mount plow like that and it really makes it nice when you are plowing on a hillside as you can adjust it for throwing the fur up or down the hill...helps alot...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 5:24pm
I have this on one of my 2000 plows.  It is great for straightening out a crook in a furrow.  It does work best with your wheel track set as the manual states but it can be used to 'adjust' for the track being incorrect, it just does a crappy job is all this way.  Does not work as vari-width.
This page was generated in 0.104 seconds.
