Disc Brakes Allis 180
jrbynf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Topic: Disc Brakes Allis 180
    Posted: 4 hours 47 minutes ago at 12:48pm
Been trying to engineer a disc brake setup for my 180.  Basically removing current dry brakes, fabricating a rotor/hub that slides over the axle with a center the same as the spline of the axle, fabricating a caliper to retain the rotor bolted into the bearing retainer of ring and pinion gear.  Thoughts?
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 7 minutes ago at 3:28pm
Just wondering why re-engineer something that has proven to work effectively for so many years
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 58 minutes ago at 3:37pm
The caliper should be designed to drop in from the top rectangle hole and be secured with external bolts. Why?? so you can easily replace brake pads as they wear without pulling the final drive/axle back off. Calipers would have to be hydraulic applied. Then, what are you going to do for a brake lock ?  trust a hydraulic master cylinder ??   Or is this a pulling tractor??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 29 minutes ago at 4:06pm
This is just a heavy use loader tractor.  Tired of wearing out brakes doing heavy work.  New brakes from A&I, shimmed perfectly to spec and still wear out with heavy usage.  I also enjoy a good project
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 38 seconds ago at 5:34pm
What is wearing out first?? the disc lining ?? Are you using the better quality/more expensive KEVLAR disc linings ?? I didn't think those could be worn out. As far as the shim clearance, I shoot for .020" to .025" which is tighter than A-C specs.
