Parts for New Idea Loader
Steve Wilkens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Topic: Parts for New Idea Loader
    Posted: 15 Nov 2010 at 10:27pm
Have a new Idea Loader, just had the cylinders resealed, left the bucket go all the way up and the cast cap that holds the seal that the ram comes out through cracked and shot fluid out. Can I get this cast cap or can it be welded. Would prefer a replacement if there are any out there. Can get a picture of it. The cylinders are about five feet long in the closed position. Dont have the exact specs, but can get them if someone might have the part. you can e-mail me, or call me at 269-275-0309. Thanks, Steve
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2010 at 10:33pm
Just wondering if something was put together wrong, it shouldn't have broke.  Make sure before you break another one.  I don't know which loader you have but New Idea loader parts should still be available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 7:45am
It was fine until I had them fully extended. Thanks for the advice.
denny sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote denny sd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 8:40am
Are these two way cylinders or single?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 1:33am
single way cyliners. they are 56 inches long and 3inches dia.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 11:42am
Steave, is what you want? I have 2 of them .  Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2010 at 1:37am
Richard, They look about the right size. But mounting points are different and the cap is different. However, that doesn't mean those caps won't work on my cylinders. Right now I have my cap at the welding shop, but thinking if a replacement cap is avaiable I might want a spare. If the welder can't fix mine, I might be interested in trying your caps. Thanks again Richard, you always amaze me with the depth of your parts inventory.
