no. 5 pitman arm length?
Badco92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badco92 Quote  Post ReplyReply Direct Link To This Post Topic: no. 5 pitman arm length?
    Posted: 17 Oct 2025 at 7:43am
This information appears to be unobtainium - does anyone have specs on the pitman arm for a no. 5 sickle bar mower? I really just need to know overall length. I’m looking to make one out of some pallet scraps while I refurbish this mower back to working condition. Thanks all!
'45 C // '47 B // '94 4660
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 7:51am
 The standard wooden pitman arm for an Allis Chalmers No. 5 sickle bar mower is
26 inches long. The correct part is also compatible with the Allis Chalmers No. 3, No. 4, and B/C sickle mowers manufactured in April 1949 and later.
< jsuid="z3Uoje_i" ="0" -amic="true" -icl-uuid="66c06a3d-910b-437f-b17d-c2858b63ca15" aria-label="View related s" ="rBl3me" js="click:&z3Uoje_h|S9kKve;mouseenter:&z3Uoje_h|sbHm2b;mouseleave:&z3Uoje_h|Tx5Rb" -ved="2ahUKEwiH-Py5oquQAxU0CjQIHdf-FIUQye0OegQIARAC" -processed="true" style="margin: 0px 6px 0px 0px; border-width: medium; border-style: none; border-color: currentcolor; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
When buying a replacement pitman, you can use either the original AC part number 802093 or an aftermarket equivalent
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badco92 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 8:01am
26”….. THANK YOU GATZ!!!!!!!!
It’s been an absolute headache trying to research that info…
… maybe I’m just getting old!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 12:49pm
There are 2 different pitman sticks used on the #3, #4, #5 and the B/C mower.
  Which on you need is determined by the type knife connection you have. Clamp on or spring loaded.
 You can figure out the length needed by yourself: Move knifer to either inward or outward position with a section centered on a guard, Position the crank arm in the matching position and measure what is needed between the straps at each end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badco92 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 6:40pm
Well... see here's my problem. The mower is currently stuck in place due to sediment and corrosion from sitting in the dirt for years, so theres really no way, at the moment, to move the knives. The old Pitman rotted off due to this.
There is a spring on the cutter bar, just inside where the pitman would be. I'd assume that means spring loaded.
I guess all things considered I'm not completely concerned about an exact measurement, but a ballpark number while I get the cutters free is fine. Then I can update back here with some data when I get it all sorted out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 7:01pm
you could buy the longest one and cut if needed
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2025 at 8:55pm
My parts book dated 4-1962 shows only the updated pitman stick for #5 mowers. You can purchase the pitman sticks here: https://awtractor.com/product/allis-chalmers-3-4-5-b-c-sickle-mower-pitman-stick-802093/
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2025 at 12:06pm
 The reason being: In production only the newer parts are used. If someone has the older knife end pitman straps, they will need the corresponding pitman stick to go with the early design straps. Whereas if the have the newer knife ends, they need the newer pitman stick.
This page was generated in 0.348 seconds.
