M&W Oil Pan For IH Tractors
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: M&W Oil Pan For IH Tractors
    Posted: 06 Aug 2025 at 10:08pm
I know they are hard to find, but a friend of mine is looking for one. Any help to find one would be appreciated.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 6:36am
Good luck, they are hard to find. Tell him to have his checkbook fully funded if he finds one! They usually go for around $7500. There is a guy that is working on reproducing them for about half the money, I think.
Steve M Ind View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 6:58am
What’s so special about them?
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 11:40am
There is a company reproducing them now. Can be had much cheaper than the originals go for but still not cheap. Cant remember the name right off hand.
Making a living farming with and working on Allis Equipment
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 12:04pm
The M@W pans are deeper to hold more oil and oil have cooling fins molded into them
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 9:21pm
When M & W turbochargers were installed on say an 806/856 diesel tractor, they needed help keeping things cool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 3:36am
Doc, that wasn't as much of a problem with the Red ones as it was with 4020's. One reaason there is not a lot of them out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 7:27am
The M & W boys had a good business model. Make parts to up the HP of your tractor and then when it overheats (because of their parts) they sell you a deeper alunnerman oil pan and maybe a larger radiator. Genius !!   In the case of the WD-45, a starter drive that could turn the engine over with 6 volts after installing their pistons and sleeves.
This page was generated in 0.426 seconds.
