D17 engine seizes up when it warms up |
djake
Joined: 14 Nov 2019 Location: Green Isle, MN Points: 36 |
Topic: D17 engine seizes up when it warms upPosted: 06 Aug 2025 at 7:26pm |
My D 17 series 1 suddenly stops when engine gets up to running temp and the starter won’t be able to turn it over again. If I let the engine cool down good , it will start right up again. It will repeat the same problem if I let it run. It is never running hot, but at normal running temp. I had recently put in new pistons and liners, which I did with the engine in the tractor. Any ideas what might be going on?
ac45dave
Posted: 06 Aug 2025 at 8:09pm |
piston to liner clearance too tight????
DrAllis
Posted: 06 Aug 2025 at 8:19pm |
Piston pins not centered more likely.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3164 |
Posted: 06 Aug 2025 at 8:44pm |
Did you get the rods turned right when you assembled the engine? Just had a WD45 reworked that I bought that was doing about you described,No 2 and 3 were wrong.
Docdan
Joined: 14 Dec 2023 Location: Wmsburg, PA Points: 5 |
Posted: 06 Aug 2025 at 9:03pm |
Are the rings gapped correctly? I had the same problem when I forgot to gap the rings in an earlier rebuild, I was 16 yrs old at the time.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8871 |
Posted: 06 Aug 2025 at 11:10pm |
Yah. If you don't put the rods in right and center the pins in the bore you will mess things up.
SteveM C/IL
Posted: 06 Aug 2025 at 11:13pm |
If you didn't clean the lower bores totally your sleeve may be getting squeezed when hot and be grabbing the piston.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89955 |
Posted: 08 Aug 2025 at 8:05pm |
this is from the WD-WD45 manual............ but you get the idea...
