Belt pulley oil seal on B |
Freewheeling
Joined: 05 Nov 2017 Location: Wisconsin Points: 170 |
Topic: Belt pulley oil seal on BPosted: 31 Jul 2025 at 8:33am |
I pulled the old leather seal on my IB and replaced it with a CR rubber lip seal # 13865. I noticed that the shaft has oil return grooves in it. It appears that the seal is on the surface before the grooves but I'm not sure. Do you think this will be OK or should I fill the groove with JB Weld? Thanks.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90653 |
Posted: 31 Jul 2025 at 9:50am |
best just to monitor it and see if it leaks..... Might be OK... Others have done the JB weld in the groove or bought a stainless sleeve to go over the shaft ( speedi).....
------------ SKF Speedi-SleevesThe SKF Speedi-Sleeve is a thin-walled, 0.25 mm (0.01 in.) sleeve designed to repair worn shaft surfaces, making them suitable for radial shaft seals. It is easily installed over the worn area without the need for shaft disassembly or machining, helping to minimize downtime. The original seal size can still be used, so there’s no need to keep a variety of seals on hand. Edited by steve(ill) - 31 Jul 2025 at 9:52am |
Freewheeling
Posted: 31 Jul 2025 at 10:33am |
Thanks. The shaft looked good so maybe I'll get lucky. I plan to flush the tranny with diesel fuel only because it's cheaper than kerosene, then drain and run universal transmission/hyraulic for a few minutes, then drain and refill with the same. Are any of the diesel additives a potential problem? Any tips?
steve(ill)
Posted: 31 Jul 2025 at 4:36pm |
how bad is the oil ??? I would be tempted to skip the diesel unless it is pure junk. Put the hy/trans oil in and run several hours.. Wait a few days or a week... Then drain and do the final fill...you could use something CHEAP for the flush and drain..
dont forget the old final drives... they normally get neglected ! Edited by steve(ill) - 31 Jul 2025 at 4:38pm |
