7060 lost Hydraulics
Howard Ward View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard Ward Quote  Post ReplyReply Direct Link To This Post Topic: 7060 lost Hydraulics
    Posted: 20 Jun 2025 at 5:22pm
Hello, hopefully I'm I'm the right spot for this.  We have an allis 7060 that we use as a rake tractor, last fall mid 3rd cutting it lost the hydraulics and 3pt mid rakeing. The power shift and steering are both functional still.
Context: I pull an Allen rake (knock off darf). It uses a single hydraulic remote and then the oil is directed to the desired cylinder by an electric valve body mounted on the rake.
After turning around at the end of a row and getting everything set I usually return the remote to neutral so the hydraulics don't buzz full time, this particular time I forgot to disengage it, so I turned around set the rake down, and made my pass, when I went to re engage the remote I noticed it was still in and went directly for the electric switch, nothing happened. I fiddled  around with it for a minute and concluded I wasn't going to take off and work, so I headed back to the shop and checked the hydraulic oil a d it was lower then I'd like to admit (almost 5 gallons) after filling it the hydraulics still didn't work,    which is when i discovered the 3pt also had stopped.
Needing to get the hay off the ground I finished raking without Hydraulics and the tractor got parked for a "winter" project. Well winter is gone and now it's time to actually fix it.  Any help or suggestions on what could cause this would be much appreciated, I'm about to change the hydraulics filters and go from there.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard Ward Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2025 at 8:40pm
Ok, I changed the oil filters and continued trouble shooting from there And determined there was no charge pressure. When I pulled the compensator spring (number 29) it was broken in half. Does anyone know where I can get a new spring? It's for the piston pump on a 7060. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2025 at 8:52pm
An AGCO/Allis dealership is the only place and you will possibly need shims to adjust the pressure.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2025 at 8:53pm
You will probably have to get a complete compensator
Finding that spring for a cesnna pump is iffy im afraid. That design was bought out by eaton. You might get lucky at a really good hydraulic shop. Some of the salvage yards should have a compensator. I hope you can because i priced a compensator a few years ago from agco and it was 800 dollars
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 10:29am
70267160 is the PN  several dealers stock and any Agco dealer can order get a few of those high dollar shims as well..
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 10:30am
lately when trying to get any hydraulic part - most salvage yards will not pull a piece off and sell separate.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 12:51pm
   I have a whole pump I would sell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 9:03pm
Howard were you able to get just a spring
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard Ward Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 9:12pm
I was able get just a spring from midway Power parts for 41 USD. I am looking through the service manual right now to see if I can figure out how to test the charge pressure.i did t get any shims so hopefully the old ones will be sufficient
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard Ward Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 10:02pm
Ok to wrap up this thread, I got the new spring put in and it fixed the ol girl right up. Huge shout out to @allisdoctor for helping me get the charge pressure set. With the thick shim and 3 thin I ended up at 549 psi. I appreciate all the input on the thread. Thanks everyone.
