Where is the serial number on a D19?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Where is the serial number on a D19?
    Posted: 12 Nov 2010 at 9:17pm
Tractor data says on "top of axle below the seat".  I looked....couldn't find it.  Can someone give me a more specific location to look?
Thanks in advance,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 9:22pm
Behind the seat.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 9:23pm
Is in actually on the small portion of the axle casting back there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 9:26pm
I believe it is the top of the rear end casting behind the top cover. stamped down so it is readable from above
Allis Express
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 5:40pm
If it has a bracket for the top link of a 3-point set up it is under the bracket.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 6:58am
Found it.  It was partially under a decal and several layers of paint.  Thanks for the help!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 5:02pm
Mine has a number on the rear end like normal but also a number stamped at the torque tube flange like a D17 but the numbers don't match. Whats' up with that? all others I've looked at have no number on the torque tube.
Wink
I am a Russian Bot
