G spark plug
w3grant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote w3grant Quote  Post ReplyReply Direct Link To This Post Topic: G spark plug
    Posted: 18 Jun 2025 at 6:49pm
I’m working on an Allice Chalmer G and three of the spark plugs are threaded directly into the head and one a spark plugs has a threaded spacer on it I have seen some pictures with them on it and some with them not are they needed and if they’re not needed what plug do I run?
Thanks Warren
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 7:54pm
normally the spacer is added for one of two reasons...
possibly .... Original threads in the head are bad so they loctite in a spacer permanent. then put the plug in it...
the MAIN REASON .....If the engine burns oil and fouls a spark plug, putting the spacer in , moves the plug out slightly and may keep it from fouling as often.. possibly never.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 8:32pm
Autolite 295 for the plug, you can use a 303 if you feel the need for a hotter plug
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2025 at 5:59am
Turn that around Joe. The 295 is hotter than the 303. Go by the last digit for the heat range in Autolite. Obviously, 5 is higher than 3 so 5 being the hotter heat range. Your right in your assumption, hotter in a worn engine or oil control issue.  As Stevo said, one of the two is probably the issue. Bad threads or bad rings in that one cylinder...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2025 at 7:02am
LOL!, correct as always Steve, what do you expect, I’m getting older and forgetful
Ford 345C TLB
