Dual wheels for a wd45 ???
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Topic: Dual wheels for a wd45 ???
    Posted: 12 Nov 2010 at 9:48am
  Does anyone have a picture or the the stuff to add duals to a 45  they would sell.  I have one I would like to put duals on ,   thanks for help.
Edited by mark-east-tn - 12 Nov 2010 at 9:48am
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 10:38am
I have 2 or 3 pair of them, I will see if I can find them. I will get you a pictuer later. Richard
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 11:08am
Best dual setup is to use another set of the stock wheel assemblies and turn them around backwards with the dish facing out, and bolt them on using a longer lug bolt right to the center hub.  Swap sides with the reversed wheels so the tread points the correct direction.  We ran one for a long time like that with all four tires loaded.  Looks good too.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 4:19pm
I run two Power shift wheels back to back for duals on my A-C 715B backhoe. The rims are from D-17IV and the tires are 16.9 x 28. I had to make an axle extention for the backhoe to get the correct offset so I made the hub wide enough for both rims to take the load off the studs. Use it with an 8' stone fork for picking stones on worked ground.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 10:17am
I have a couple pages from the Allis Chalmers serice manual detailing installation of these. I think it was for a D14 but would be the same idea on a 17. It is just like some of the posts are on here with the center hubs front to front with a spacer ring that sits in between the wheel flanges. I will see if I can find it and post it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 11:18am
I'd like to see pics of them too Richard. Can't wait to see them!! Thanks
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 11:58am
Mark, I sent you a PM, I'm in Roanoke, VA
