2-12 plow depth link
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Topic: 2-12 plow depth link
    Posted: 28 May 2025 at 7:22pm
My model 4 has long rear landslide.
My question is about the link that goes from the axle lift to the depth control lever(  left side in Tractor seat) .
I cannot lift the plow with lever to plow a 6 inch depth furrow. I’m going to deep. The lever is all the way down locked.
I was told that the model 2 has a link with three holes in it.
If you’re familiar with that plow could you please verify that.
I would also like to know the distance between each hole ? This would be a great help.
I measure mine and it was 17.5 inches approximately center of holes in link rectangle lift bar .
My manual sayes that the tires should be 5.00-16. ( 25.5 outside diameter) I currently have 4.6-16 motorcycles tires which are not quit 25 inches out side diameter.
Thanks for your comments
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 9:20pm
I think I have the same plow, will check tomorrow and measure.
I think that is what mine is, it measures 17 inches hole to hole, I have 6.00 16 tires off a WD on mine and it works fine.
Edited by jiminnd - 29 May 2025 at 11:00am
This page was generated in 0.192 seconds.
