Wanted: Split Rims for Model B
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: Split Rims for Model B
    Posted: 23 Apr 2025 at 7:08am
Looking for a nice set of split rims (split bead) for an early Model B tractor. Thank You!
https://www.allischalmers.com/forum/uploads/21138/20230823_194648_compress62.jpg
Edited by GreenOrange - 23 Apr 2025 at 7:04pm
Steve in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 6:22pm
guess I would have to see a picture can't say have ever seen split bead on block allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 6:23pm
spell check kicked in again B allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 6:51pm
I have seen a couple at tractor shows... on pre 1940 tractors... always wondered if it was factory, or taken off semi truck.. they were 24 inch..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 6:56pm
i have a bunch of B's 1939 and up but none have split rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 6:59pm
yep...i have "heard" there were a few built in 1938.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 7:01pm
The earlier 1938 tractors had them. I put a link to a picture in the original post.
Edited by GreenOrange - 23 Apr 2025 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 7:22pm
In my earlier days on the farm, we had a B with a 3 digit serial number that we were very sure was all original when we got it. It had lock ring type rims. One was nearly unusable as it had probably has CaCi in them since new.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 6:19am
I have some clamps but no rims.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 5:47pm
well Iearned something new, will have to watch at the shows and see if I can find one thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 10:09am
Keep seeing 2 or 3 piece rims called SPLIT RIMS - They are not , what are called lock ring rim where a outer ring is held onto full width inner rim by a lock ring which is either a 1 or 2 piece fixture held in tire bead area .
 SPLIT RIMS were 2 pieces and joined in center section of rim by fitting the 2 halves together by deforming one half over other and then locked together with groove area. Bead area of tire fit onto each half with lock at center to join rim to working fixture .
 Picture shown is a 2 piece rim with split lock ring - rim would have size at bead area the same for inside and outside area to fit tire inner bead diameter . A 3 piece would have slight step down at outer bead area
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 10:20am
https://youtu.be/PesIdB2wFjI?si=RwQvZRNgvMYB6TMg
Smaller rim but shows difference -
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 5:33pm
These are rusted out but here is what they look like
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2025 at 12:23pm
That is a lock ring wheel. They were used on Dodge/Ford pickups until about 1968 and US military vehicles and International trucks into the 1980s.
Very different than split rim -aka "widow makers"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2025 at 4:45pm
Agreed - they’re not split rims. I’ve heard them called split bead, split ring, and lock rings, and definitely understand the difference. I called them split rims in the title because that’s how they’ve been discussed on this forum and how they’re often referred to for the B. If they actually did use true split rims on this tractor, I personally wouldn’t even mess with them. This style I can work with, albeit carefully.
Edited by GreenOrange - 26 Apr 2025 at 6:13pm
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2025 at 4:20pm
I have a set on a parts B tractor in dark back storage...need to sell whole tractor to keep it rolling....bought it to fix up 1935 IB.....Mark
Vern from MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vern from MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 10:35am
I have one complete split rim for a Model B with two sets of brackets to hold it to the center dish.  The split rim needs a little welding from 1 thru rust spot.  If interested I can bring it to the Orange Spectacular in Hutchinson, MN in July otherwise I work in the cities in MN.
This page was generated in 0.710 seconds.
