Allis Chalmers All Crop be careful sign difference
Collin Moore 2010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Collin Moore 2010 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers All Crop be careful sign difference
    Posted: 13 Apr 2025 at 7:52pm
Hi, everybody, my name is Collin Moore and I am 14 years old. I own a 1948 Allis Chalmers All Crop 60 combine. I rescued this machine out of a woods that it had been sitting in for 60+ years. I put roughly 1,400 hours of labor into this machine to get it back into service. I’ve pulled it in a couple of parades and harvested soy beans with it last season. It’s a ton of fun! A couple of really cool things about it is the fact that it is an aluminum model machine instead of the normal steel sheet metal machines that you see all the time. It also has a cylinder speed gauge that I got off of my 66 parts machine that I bought out of Indiana. Anyways, ever since the first day I looked at the 60, the be careful sign on the grain tank has always caught my eye. On all of the other machines I have ever saw the be careful sign has been a white background with black lettering. However, this one is a sort of charcoal gray background with black lettering. Do I have some sort of super rare sign or did 60 years of being out in the elements get to it? I’m also thinking that since it’s an aluminum machine because of the shortage of steel back then I wonder if there was a shortage of whatever they used to make the signs. Any responses would be greatly appreciated as I am trying to learn as much as possible about the All Crop line! Thank you!
Edited by Collin Moore 2010 - 13 Apr 2025 at 7:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 8:19pm
Collin, I would suggest that you post a picture, and Welcome to the forum, if anyone knows, they'll post here...Thumbs Up
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 6:58am
Welcome aboard, sorry I have no information for you.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 8:25pm
An all aluminum harvester seems unique. Maybe you found a prototype machine that escaped the test lab?
Aluminum oxide can color finishes and other materials differently than iron red rust. So you may see a different corrosion discoloration.
Be sure and try and show other crops you've run through the All Crop! Buckwheat, rye, alfalfa, and more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 9:55pm
Aluminum?? or galvanized steel is how I remember Grampa's combine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Collin Moore 2010 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 6:29am
I tested the sign with a magnet and it is made out of some sort of other metal. It was not magnetic, so I’m going to guess it’s made out of aluminum and like you said maybe it oxidized in someway and turned a different color. I have only ran soy beans with it, but this year I plan to run wheat with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Collin Moore 2010 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 6:31am
Here it is next to a normal sign.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 6:41am
I'm betting it's just a "generic" sign installed by the previous owner some decades back.
Use google lens and you'll see some come up just like it.
CrestonM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 2:48pm
There were definitely a bunch of them made with varying amounts of aluminum. It was leftover material after the war, I think most of these combines were 1946-47. Some had more aluminum than others, and unfortunately many didn’t hold up to the strain and vibrations and have shaken apart.
Welcome to the forum! I fixed up my first All-Crop, a 1950 60A, when I was 16. That was about 10 years ago, so I vividly remember what it was like being that age and trying to learn as much as I could. Good luck on the journey, and have fun with it!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2025 at 11:37pm
My older 1948 is a parts machine (SN 158410) which has a lot of aluminum for the sheet metal. The pack rats apparently loved chewing on the edges of it. Both of my 1948s have the flat white/black painted sign.
