Stock WD45 Pistons
Lingle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Topic: Stock WD45 Pistons
    Posted: 04 Apr 2025 at 12:57pm
I know there is a classifieds section but before I post, does this forum think there is a market for stock WD45 pistons?  when I am done rebuilding one good WD45 engine (from the 3 engines I have) I will part with the 2 engines and misc parts.  Im using oversize pistons from Reliance parts(4 1/8" diameter) but figured someone may be able to use or want the WD45 stock 4" dished pistons.  Thoughts?
35 and 41 WM crawlers, 49 WD, 53 WD45 wide front, 49 JD A, 52 JD B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 2:33pm
Used "Power Crater" pistons and the sleeves ??  I guess if the sleeves didn't have any or hardly any ring edge, someone might use them. Thos old A-C Engineers seemed to have things figured out. If those engines received regular oil and filter changes and had the air cleaner maintained, when they started using oil bad enough, everything was worn out. The sleeves had a deep ring edge. The top piston ring was loose up and down in the groove. The valve guides were worn out and the center main bearing needed to be reground undersized. All depends how good of shape they are in. I have no idea what eight sleeve Orings would cost??  $40 bucks ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 3:00pm
got my rebuild kit from Jensales, liner o-rings are a few bucks a piece, so not terrible.  wish the liners were better shape, I think you could use 4 of the 8.
7 sleeves as the one engine had the #4 rod bearing cap come loose, damaging beyond repair the camshaft, removing part of the #4 sleeve and thrusting the crank forward to remove the thrust washer material on the #1 main cap.  I think in the end itll likely be a package deal, 1 running engine and a incomplete parts engine.  this started out with having a engine that leaked coolant from between the block and head to aquiring 2 new to me WD45 tractors and making 1 good engine from 3.  lesson learned...make sure the sleeves do not protrude more than spec.  prior owner put in different sleeves but were too proud of the block(I didnt see this) and it leaks profusely when you are running.  but I got 2 good rear rims(from 6 total), a good hyd pump and a bunch of sheetmetal so thats a plus!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 3:22pm
I have never installed one of those head gaskets DRY. I've always used a little something on both sides of the head gasket, around each and every water passage hole and all the way around the outside. Never had any leaks.
