Plumbing
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Plumbing
    Posted: 16 Mar 2025 at 1:48pm
Replaced a leaking toilet fill valve today. Pretty easy peasy, but kinda crazy how many different ones the big box store has. Glad I knew which one I needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 2:15pm
I try to be like NOAH, get TWO of things like that , so I have a spare when needed....
..like 2AM when you are fed up of the drip..drip.drip...drip.drip...........
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 2:22pm
Yeah Jay, I've done the same when we lived out in the boondocks. Now I'm much closer to big box stores. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 2:26pm
OK.... but I don't want a phone call at 2:01 AM  anytime soon !Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 3:56pm
I bought one last month that had this litte RED BUCKET under the valve body.. Seems like it is suppose to fill with water and hold the valve CLOSED.. If the toilet drain leaks slowly, the bucket keeps the valve from constantly opening and filling the tank.. When you trip the HANDLE the bucket is attached with a chain and it tips and dumps.. allowing the valve to open and refill the tank..
WORKED LIKE CHIT.... Could not get it set right.. Finally threw away the bucket and just let it work OLD STYLE..... I like these with the vertical float, as compared to the old "arm and ball float"...
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 4:59pm
Those early ones we dubbed "Floodmaster" as they had a tendency to pop loose and well you know. I think they are better now but be darn sure the lock ring on the height adjustment is properly snapped in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 5:03pm
Haven't seen a arm and float ball in a long time. Do remember them. I've always had good luck with fluid master. Thanks
This page was generated in 0.508 seconds.
