Old tractors
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Old tractors
    Posted: 12 Mar 2025 at 8:51pm
How many guys in your area still run old tractors? There seems to be very few around here. Even most squatters (acerage owners) have newer stuff. The oldest tractor we have and still use daily during the winter is our 8010 allis. I can't think of anyone else who uses anything even close to that age around here.
Edited by Acguywill - 12 Mar 2025 at 8:59pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2025 at 8:58pm
Doubt there is anyone around here running anything older than me. I see a couple 8xxx's from time to time. I run 7XXX's, a 200, 170 and WD45.
My accountant says I put farming back 50 years . True, I reckon
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2025 at 9:10pm
We have a 7010,7020,7045,2-8030’s, 8070. They are mostly auger tractors except the 8030 and 8070 which pull the 3 point 8 row planter and mow roadsides and brush with a 15 ft batwing from time to time.
Edited by SilverShoes - 12 Mar 2025 at 9:10pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2025 at 9:30pm
I mostly make hay with my tractors and feed cattle some loader work etc.I use a variety of 50's, 60's and 70's models Olivers 1650,1550,66.1365;AC WD45,CA;David Brown 990,780,885.Long 460,560,R9500 plus a couple compacts from the 1990's
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2025 at 9:38pm
We farm with a WD, D10,D12,D14,D15,2-D17’s, 6060,2-190XT’s and a 160. My brother uses his D10 and D12 for gardens mainly and some sickle bar mowing. Hay operation, very little tillage anymore although we have a few hay fields in need of some plowing to re seed. No till results didn’t impress me much. Quite a few AC’s locally still farming full time. Neighbor has 2-6070’s, WD, D17 S-IV 8010,8030. I could go on and on but a lot of AC’s in our county. My best friend has a 500 acre hay operation that he has many Ford’s and his first tractor he started with a AC175/loader. He does 25K bales/year and a 1k or more round bales. Most tractors in the county are older but continue to be repaired and used regularly. Not many can afford the new stuff and don’t like the technology issues. Of course there is some new stuff, just not that much.
Edited by AC720Man - 12 Mar 2025 at 9:43pm
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 5:30am
I guess it depends what you call "farming". You are correct if you consider dairy farms. I am the only one left in my area under 1000 cows. I farm with three wd 45 and a c. But i still file taxes as a farmer and unlike those 1000 cow dairies the person who does the majority of the work uses English as his primary language (me). And i did show a five figure peofit on my taxes last year
On the other hand, i did remember noting last year i was the only person i saw fitting ground with a two wheel drive tractor
Edited by dr p - 13 Mar 2025 at 5:31am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 8:18am
Lots of old iron still out there working in this part of the world! 1984 6080 is the newest one here. I see lots of 56/66/86 series IH's around, including a 1456 that goes down the road with a disc mower every once in a while. Love to know where that one lives.
Lots of 20/30/40/50/55 series Deere's too.
There are some 7-8000 series AC's but not lots.
Not as much Meadow Green out working, at least what I see. They are around, I know that. When we feature them they come out in mass.
There are piles of H's, M's, WD's, 45's and other various creatures of that vintage still earning their keep.
Big time operators mostly run the ugly green. Probably a dealer network thing mostly.
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 6:40am
For most part time and full time farmers in my area ( Middle Tennessee ) there a lot of newer John Deere and Kubota cab and FWD tractors for most part. There is several 2wd cab tractors mixed in that are probably 20 to 25 years old. Then you do find a few that still have stuff from the seventies and eighties. This is mostly beef cattle and hay farms.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 9:07am
Lots of older Allis tractors in my area still working including mine.  Quite a few of the bigger operarters around here have WD's and WD45's on their farms from new and are still using them.  I'm keeping busy reviving WD's lately for several farms as they still need a reliable chore tractor on the farm.
Just got another engine in yesterday for a rebuild to put another WD back to work.  There are well over half a dozen still earning their keep within a couple of miles of my place.  Lots of D17, D15, D14 and at least one D19 still used in farming operations around here with many 7000 and 8000 series.
Still see an occasional JD from the 60's still in use, but not near as many as Allis Chalmers.
Edited by Alberta Phil - 14 Mar 2025 at 9:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 9:58pm
We had 2 Allis dealers, one 6 miles away that served our county and another dealer about 30 miles away serving the next county. Both were there until the end and sold many AC’s over the 40 plus years they were in business. Plenty of them still around working including older K and M series combines. 7000 and 8000 series tractors are plentiful in both counties but I would say way more W, D, and 100, 200 series since most farms are 100 acres or less. There are large farms that have went with newer tractors for sure, Deere, NH, Massey mainly. Fendt has become popular over the past 5 years. We just hope we can keep getting parts and keep em running. I’m thankful AGCO and the aftermarket make a lot of parts available. Shows how much of a following AC has after almost 40 years of them closing the doors.
Edited by AC720Man - 14 Mar 2025 at 10:13pm
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2025 at 10:23pm
I farm full time. 180 185 d15 7040 8640JD 8030 8050 74 w900A kw 76 W900A 98 12R30 white 96 25ft drill 3630 spra coupe 80 M2 97 R52. All used on 1500AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 8:50am
Talked to a buddy yesterday that needs some help this spring. He's a huge Oliver and White collector. He's right at 35 miles from me, a little outside my normal area? I didn't include his stuff in my earlier post. Anyway, there might be some footage of Meadow Green and Silver in the future.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 3:36pm
I farmed from 1978 until today the newest thing here is a Deere 1250 tractor made by Yanmar. The real hp has always been Cat D6 9u series (built from 1948 until 1958). They got cheap Confused and I added more Big smile. But a AC HD 5 was always my seeding tractor. Added some of them for spare parts too.Big smile
Some place along the way grain farming got crowded by wine grapes here. So very few farmers left, mostly gentlemen farmers that don't know how to operate a tractor new or old. Everything from 5 acres to 5000 acres of vineyard.Wink But wine is out of style or at least high priced wine. Said to 50,000 acres state wide that are not needed at current consumption levels. Several big corporate farms , all new green DEF using machines. The small guys bought a new one to start and still using
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 6:02pm
In my area I've seen used:
IH 756
Farmall 350
4020 JD
80s/90s JD
70s Ford
00s Case combine
Old iron I use
'55 (family heirloom) and '58 Ferguson 35
'52 WD wide front (built within two weeks of the WD we had on the farm, brother has that one now).
Local dealer is very important to what farmers buy, for parts and service. JD has to be there with all their software lockdowns/blocking right to repair.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 6:57am
Ray, that is interesting what you said about excess wine grape production. I live in the finger lakes, which used to a hot bed of wineries. Total collapse of that economy. I think peoples taste has changed. The distillery seem to be doing better but not much
