I600won’t run right
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I600won’t run right
    Posted: 23 Feb 2025 at 4:46am
My I600 started sputtering and missing.
Reminds me of a fuel issue. I pulled the carb, soaked and cleaned it and installed a basic kit. No change.
I will say that the key ignition switch doesn’t seem quite right. It starts right up but you must not let it spring back very far at all or it dies. I’ll get that changed but I don’t think that’s the whole problem. It will start and idle well.
Give much throttle and it starts to sputter. Choke has no effect on this whatsoever.
The points on this tractor are wore out. Could they be the problem? Is there any points I can buy at the local auto parts store that will fit this?
Who sells good points?
Edited by Thad in AR. - 23 Feb 2025 at 7:21pm
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 5:39am
I'd suggest go through the ignition & even if the points are worn make sure they're gapped as close as you can get. 90% of "fuel" issues turn out to be weak/badly timed spark.
If you replace the points, consider keeping the old condenser (or finding old stock) unless it's bad as new ones seem to be worse than old stuff.
Obviously I don't know a good source for points sadly, my Allis is on a Ford distributor lol
Edited by ekjdm14 - 23 Feb 2025 at 5:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 6:02am
ign switch, definitely change it, when they get wonky, will drive you nuts.  Second, check your wiring, specifically check the polarity of the coil, - should go to points, on a - ground system.  also check plug wires, common mistake is firing order, 1-2-4-3.  If an IH mechanic has been at it, some wires might be reversed! Before replacing points, consider converting to pertronix system, its the same labor as points, but this will be the last time you have to do it...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 6:09am
Will do Dave. It was running perfect while digging some footers this spring then it just started sputtering like running out of gas or clogged carb. Choke makes no difference which makes me think electrical.
Switch has gotten Wonky for sure.
May try it with ignition unhooked and a jumper wire just to see what that does.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 7:50am
Have you checked the Air Cleaner path for any restrictions / blockage
Also removed the Gas Line at the Carb to verify Fuel Flow.
G
Link to Tractor Data Website   1966 to 1968
https://www.tractordata.com/industrial-tractors/000/1/7/173-allis-chalmers-i400-dimensions.html
Link to I-600
https://www.tractordata.com/industrial-tractors/000/0/8/85-allis-chalmers-i600.html
Edited by Gary - 23 Feb 2025 at 8:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 8:06am
you can just run a jumper wire from the battery to the coil.. no need to disconnect the switch to test.........
sure sounds like its time to do the point and condenser.. like mentioned, sometimes the OLD condenser is worth keeping.. but if you dont CHANGE it out, you wont know if it is the problem..... I had a similar problem a few years ago and it ended up being a weak coil... NAPA or AUTO ZONE should be able to supply the parts... or several on line sites.
I did have one tractor that a mud dobber had built up a nest inside the air cleaner cap and was restricting air... would not rev up..how he got thru them little holes i will never know.
Edited by steve(ill) - 23 Feb 2025 at 8:25am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 10:31am
I did that in reverse order about a year ago. Wired my 400 1-2-4-3, ran on 2 cylinders. Pretty sure it's supposed to be 1-3-4-2. I did learn that a Farmall 400 will run on 1 cylinder in the process.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 11:35am
My Model C Allis was parked outside and somehow rain got into the air filter oil cup, then when freezing weather came it solidified into something resembling ice cream; not quite solid but it would not pass air. No start, of course.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 5:51pm
Thad sent you a PM. Kenny
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 7:20pm
A couple updates
I had an old distributor on the shelf. I pulled the points and condenser out of it. I installed them and it wouldn’t hit .
I had a spark tester and it showed to be firing. I pulled the drain under the carb and had a steady flow for several minutes. I reset the points a few times and swapped back to the old condenser and still no luck.
I removed the hose to the air cleaner and no luck
I ran a jumper wire to the coil and no luck.
I switched coils and no luck.
I ran out of time as it’s my afternoon to go to the nursing home to visit my mom.
I put a battery charger on it and left.
When I got home it still wouldn’t hit.
For whatever reason I squirted some carb cleaner in the carb and it fired right up. It even kept running but would start to sputter so I’d give it a squirt and it would clear up.
I’d say my gas is bad.
It doesn’t smell bad or look bad but I think it’s bad.
I ll update when I get it figured out for sure.
Other update is, it’s an i600 not a 400. Don’t know where I got that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 7:26pm
bad gas ........... or maybe your main jet is plugged ???   Easy to get a floating piece of rust/ dirt in the system and STUCK in that little jet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 7:33pm
Situations like this can be very frustrating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 5:02am
Yes sir it eats up a lot of time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 5:07am
My thoughts exactly.
I’m afraid it may be a plugged jet.
I cleaned the carb meticulously and ran a wire through every jet. Cleaned some more and shot carb cleaner and air through every jet.
I guess I’ll drain the gas and put in new and try that first then I’ll take the carb apart again if needed.
Power valve and air fuel mixture screw don’t change this at all.
Straanger View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 12:25pm
Get a gas tank for a roto-tiller or snow blower and clamp it above the carb. Find out real quick.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 12:45pm
He said he had a good flow of gas out the drain of the Carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 12:50pm
--------For whatever reason I squirted some carb cleaner in the carb and it fired right up. It even kept running but would start to sputter so I’d give it a squirt and it would clear up.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 1:00pm
So with my Post and then Steves Post one would conclude that the fuel problem is
inside the Carb because the fuel isn't getting from the Carb to the Engine.
G
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 4:38pm
If it runs fine until it warms up - could be the coil as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 6:50am
Given that some thought but it will run with a squirt of carb cleaner.
Wondering if vacuum leak, bad fuel or still plugged.
I’m going to have to give it some more trial and error time.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 7:42am
If it runs when you spray carb cleaner in the Carb air intake, the carb cleaner is taking the place of the Gas - air mixture.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2025 at 5:50am
Yesterday I drained all the gas from the tractor.
I pulled the valve and rinsed the tank with more fresh gas.
I cleaned the valve and sediment bowl and put it all back together.
I then opened the carb drain and ran fresh gas through it.
Put the drain plug back in and it fired up and ran perfect.
I’m still not satisfied gas was the problem but it started and ran like it should.
Today I need to use it some. We’ll see what happens?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2025 at 8:20am
could be old gas, but them low compression engines will run on about anything.... when you open the carb drain and FLUSh, you might have flushed out a small chunk of rust that was setting in the main jet... either way, ITS FIXED !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2025 at 7:29pm
Started right up this morning I went to move some stuff around. Before I got the chains hooked up it started sputtering.
I had an old coil in the shop. It was cracked around the top.
I put it on and it ran fine the rest of the day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 3:47pm
Hmm, who was it that said it could be hot coil issues  ?  :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 5:40pm
Yes sir and you were correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 5:47pm
Earlier it was running on starting fluid.. but not the carb.... Sounds like you had 2-3 Different problems...The recent TUNE UP was surely needed..
Post Options Post Options   Thanks (1) Thanks(1)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2025 at 4:01am
The points were wore out worse than I’ve seen in a long time. So yes the tuneup was needed. I’m not sure why it hit on the carb cleaner. Once it hit it stayed running on gas?’
Also at that time I had the coil (6volt ) from my b on it.
I then switched back to the original coil and it fired up and ran great. The next day I tried to use it . It ran great for a few minutes then it started running bad.
I had an old coil in the shop. Top was cracked but I decided to try it.
It ran good for the time that I used it. Ran probably an hour or so.
I believe the tuneup and carb cleaning and kit were needed but I believe the coil was the problem all along.
The choke and power valve adjustments made absolutely no change .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2025 at 8:41am
Originally posted by ekjdm14 ekjdm14 wrote:
... 90% of "fuel" issues turn out to be weak/badly timed spark.
Ahem... Wink
Glad you got to the bottom of it in the end, not had many oil coils actually go bad (as opposed to physical damage/rust) but they can be a head scratcher when they do let go.
Edited by ekjdm14 - 05 Mar 2025 at 8:42am
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2025 at 3:37pm
 I was going to say that maybe your connection to the points was on the wrong side of the insulator... but you got it to run on carb cleaner so it wasn't for lack of spark.
Thad, I can kinda relate to your frustrations a bit. I had issues with my 170 from December till mid Feb. I blamed it on bad gas, crap in fuel tank, bad ignition and even maybe having crap in the carb. I put on new points, condenser, rotor and cleaned the contacts in the cap, and cleaned the fuel system and tank and carb, tried a different rotor and cap (big mistake) from another 170 and that backfired and spit gas and flames out of carb setting it on fire, (cap wires were one hole off) put fire out with extinguisher and ordered new carb kit, cap, and second set of points, condenser, and rotor . Tractor now starts and runs... and I don't know what was really wrong. Maybe I had couple bad condensers, or maybe the rotor from an AI package or the cap or possibly the points that still look like new.
 After I got it running again, I put a new IGN switch on to replace the 57 year old switch.
