How many miles can get on full tank with allis b
LiL B Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LiL B Orange Quote  Post ReplyReply Direct Link To This Post Topic: How many miles can get on full tank with allis b
    Posted: 21 Feb 2025 at 12:17pm
How many miles per gal can I get with allis chalmers b it holds 6 gallons and burns 1 gal per hour
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 12:21pm
you should be traveling 6 mph or a little more... so 35- 40 miles would be a good guess... take an extra gallon jug next to you on the seat if your close..... i actually thought the tank was a little bigger than that, but i have not measure it.. Stand tube inside would change USABLE gas.
Edited by steve(ill) - 21 Feb 2025 at 12:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 1:33pm
 The tank is larger than 6 gallons,  The manual says; 13 gallons. However I do believe it is actually a little bit less.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 3:30pm
A 5-gallon can of gas doesn't fill my Model C even halfway. Same tank as a standard Model B.
I cannot imagine sitting on that thing long enough to run it out of gas! LOL
Edited by Les Kerf - 21 Feb 2025 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 3:34pm
over the years, "MOST" equipment was designed to run an 8 hour shift... Your burning 1 gph at road speed.. If you were plowing you might burn 1.5 gallons an hour ?  Again, i have not measured, but i would think the tank was "designed" to hold around 12 gallons.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 4:24pm
My 'Tractor Specs Chart' shows a 'B' and 'CA' at 13 gal and 'C' at 12 gal.
G
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 5:25pm
We had a neighbor who used his B to cut hay with an old horse drawn mower. He didn't have a skid tank, so he would go up to our neighborhood gas station in the morning and fill the tractor to about a couple inches from the top of the tank. He explained that the cool gas coming out of the underground tank would expand faster than he burned it on a hot day.
