Fender modificaton ???
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Fender modificaton ???
    Posted: 20 Feb 2025 at 3:55pm
Photos to come.
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 11:47pm
I modify all my Fenders.  First is I pull the four screws and remove the neck, then I cut a pair of crossways grooves and sink in an "X" made of brass square stock, then mix up some epoxy, coat the mating faces, clamp and screw it back together tight, then fill the body to neck gap with epoxy so it can never come loose.  Then I shave off as much material from the heel joint, to grant better hand-clearance to the upper frets.
Then I nix the volume and tone controls... direct wire, and add in a mini-XLR in parallel with the 1/4" jack, and affix a pouch to the body to hold a wireless transmitter.
I've also taken to carving out a recess and fit a headless bridge/tailstock tuning assembly, and chopping off the original headstock... it sure makes it easier to navigate around a crowded stage without whacking a mic stand or bandmate.
On my Musicman Stingray-5 (which is a Leo design), I put the body in the Bridgeport and cut out about half the material.  Between that, and the aforementioned tailpiece/headstock work), it went from 13.5lbs down to 8lbs, which really makes a big difference for a 4-hour gig...
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 4:38am
You should also have the amp that goes to 11...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 9:22am
GEES... i thought he was talking about a TRACTOR  !  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 11:16am
But Dave...  My amps all go up to 30... Wink
In prior years, it wasn't uncommon for me to run significantly more power, but modern stage technology means I don't need to do that anymore... but I still have four 18" sub cabinets and four 2600w amps in the racks... once my new shop is weathered in, I just might hang them from the ceiling corners... it'll make cleaning dirt and old paint off the tractors much easier... turn it on, and walk away... LOL
The other modification I do to my Fenders... is remove the strap peg, replace it with a 5/16" threaded stud set in epoxy... I attach the strap permanently, as EVERY so-called 'strap security' accessory breaks... dropping the instrument.  Can't have that.
Steve- I'm bumpin' it to the top, 'cuz I wanna see his pictures!!!!
Edited by DaveKamp - 24 Feb 2025 at 11:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2025 at 4:15pm
YEA..... I been a waitin for PICTURES !!  Narrow this down a little.. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 12:54am
I'm wondering,,,,,,,,,,,,,,are we talking about guitars or tractors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 1:21am
That's a great idea, Ted-  an orange tractor-shaped guitar!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 3:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 12:13pm
This post needs pics...
SOmeone needs to tell her, Never push down on the crank, only pull up! Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 12:41pm
Good thing that's just a big-block V8... LOL
Lessee... I see unstyled WC radiator and fuel tank.  I THINK that's a WD trans stick, but an early WC rearend housing??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 12:57pm
there was a tractor in the video ?  Wink
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 10:33pm
i would like to know what the front hub caps are of off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 1:04am
Works a lot better if you push down, pull up, push down, pull up,,,,,,,,,,  you get the idea...only faster.. WinkBig smileLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 9:43pm
Ted's such a naughty guy...
How's the ice'n snow up there Ted- you gonna send me a flood this spring?  lookin' a two inches of rain projected for Tuesday, and soil is frozen a few inches down, so it's gonna puddle and run off...
This page was generated in 0.054 seconds.
