Most effective way to remove paint
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Most effective way to remove paint
    Posted: 08 Nov 2010 at 2:01pm
We use a sandblaster which seems to work alright...the only problem is you spend a fortune on sand and it could wreck seals...what are some other products used?
"Better By Design"
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 2:23pm
Airplane paint stripper
Electrolysis
Wire wheel
Abrasive pad for angle grinder
Charlie
Hartland Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hartland Farm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 2:34pm
I use a produce called Super Strip that Sherwin Williams sells. It's a gell that soaks into the paint and after a short time you can just lift the paint off with a puddy knife. I don't let it get into my seals and it's hard on any thing plastic but it makes it easy to get the old paint off. It mixes with water so clean up is not bad.
Joe
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 2:57pm
Paint stripper from HDepot then sandblast.  You say you spend a fortune on sand??? I use the premium playground sand from lowes, costs around 3.00$ per 50lbs.  I then screen it through a window screen.  I only use it once but I would imagine it could be used at least twice before the edges are gone.
Bob, North Carolina
1949 B
bluebanshee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluebanshee Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 5:57pm
Oven cleaner takes grease and paint off well. I've used Klean Strip and sprayed it on with a (upol) undercoating gun.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 12:06pm
Needle scaler for cast iron pieces.
Bertman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bertman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 7:16pm
We use silica sand all the time. We have a blasting cabinate sp? that works alot better after its been used alot more. I think the finer it gets the better it works
