Model B final drive question.
Tcfcowboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcfcowboy Quote  Post ReplyReply Direct Link To This Post Topic: Model B final drive question.
    Posted: 13 Feb 2025 at 7:30pm
I have a 1938 B that I m currently restoring, the right final drive is cracked around the drawbar. Would final drive from a 1940 B work. The reason I ask is, someone told me the early models had a different final drive, however they look the same to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 7:56pm
Should interchange fine... Some have said the gear ratio is slightly different.. I can not confirm that... The housing would definitely be the same... The draw bar mounting holes on the earlier tractors were 1/2 inch i believe, and the later were 5/8 inch.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 8:15pm
I have heard that there were some different final ratios over the course of production as well, and I would love to see conclusive info on that. I have found several different ground speed ranges given depending on the year of the sales literature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 8:20pm
I just looked up in the PARTS book and they list ONE bull gear for the B... but a couple options for the C.... As John said, the ground speed seemed to change over the years and SOME have said this is due to the final drive ratio.... I tend to think it is more related to the TIRE SIZE and GOVERNOR speed which changed over the years...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcfcowboy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2025 at 6:51am
Ok thanks, I’ll count the teeth, and check the size of the bull gear.
