1960 Roto-baler with Overdrive |
Page 12> |
| Author | ||
wjohn
Topic: 1960 Roto-baler with OverdrivePosted: 04 Feb 2025 at 7:47pm |
I found a slightly better candidate for fixing up than the $50 Roto-baler I bought last year. This one is a 1960 white top with overdrive.
The roof is slightly bowed in from someone probably storing something on top of it, and the safety shields over the intake are missing. Otherwise it seems to be in good shape and has spent most of its life inside. I am going to have to break down and get belts for it - they didn't look bad from the ad, but the lowers are delaminating. I must be nuts to put $800 worth of belts onto a baler so I can bale and hopefully sell $100 of straw this year? ![]() ![]() ![]() |
| Sponsored Links | ||
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 04 Feb 2025 at 8:20pm |
You'd only be crazy if you try to transition it into something else, other than what it IS...
dr p
Joined: 24 Feb 2019 Location: new york Points: 1536 |
Posted: 05 Feb 2025 at 5:27am |
They actually made fewer white tops with overdrive than number 10's. I have some barely used spliced bales if you need some
wjohn
Posted: 05 Feb 2025 at 6:51pm |
That is an interesting point - supposedly 750 white tops with overdrive, vs. 1500 #10s? Of course, an unconverted #10 would still be much rarer. I'll send over a PM about belts.
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 792 |
Posted: 09 Feb 2025 at 10:27pm |
and the over drive does?
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 582 |
Posted: 10 Feb 2025 at 6:33pm |
Overdrive? Also, my question, been around them but they were "not overdrive".
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 10 Feb 2025 at 7:53pm |
Isn't that the Reversing Gear? |
wjohn
Posted: 10 Feb 2025 at 9:19pm |
It kicks in to increase the speed during the twine wrapping cycle, then kicks back out when ejecting the bale. It just sped up the wrapping by a few seconds. I'm pretty sure I've seen a video of one in the field on YouTube but I'm not sure I could find it again. They talk about it briefly during the Roto-baler history walk at the Orange Spectacular:
Edited by wjohn - 10 Feb 2025 at 9:19pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4275 |
Posted: 11 Feb 2025 at 8:09am |
Speaking of Hutchinson, are you going to be in attendance this year?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 11 Feb 2025 at 3:50pm |
The need for speed is just part of a man....
wjohn
Posted: 11 Feb 2025 at 7:50pm |
I hope so! I won't be bringing anything to show, but I'd like to get up there and see folks again and buy another truckload of parts. It will depend on how much vacation I have left after farm activities. You going to be up there again?
wjohn
Posted: 11 Feb 2025 at 7:53pm |
Ha! Ideally the bales would shoot out the back quickly onto a rack too and I'd be baling in record time... but can't have everything. I have always wondered if anybody ever made a tow behind sort of drag accumulator to group a few bales together in the field.
DiyDave
Posted: 11 Feb 2025 at 8:04pm |
Back when I was farming, I took a 4 wheeler with a snowplow, start in the middle of the field, and drop the plow to an inch or so off the field, start pushing the row of bales toward an edge. When I couldn't push no more, I turned around and pushed toward the other edge. Then pushed from the edge toward each pile in the middle, the resulting piles might be 30, might be 50 bales. Sure saved a lot of labor and walking...
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 12 Feb 2025 at 8:00am |
back when Dad still had a Rotobaler, my oldest brother would gather the bales with a Farmhand F10 mounted on a WC. My other brother and I would be up in the hay mow stacking them. Of course it was always the hottest day of summer…not the slightest breeze either. Sweat like an old mule!
Later, Dad got an F20 to mount the Farmhand on. It was better suited for the task beings it was heavier and you sat up higher. (forget any semblance to “speed-shifting”) We stacked a lot of hay using that rig, then later we stacked chopped hay in a cage. The D17 Diesel & #50 chopper did the job. Edited by Gatz in NE - 12 Feb 2025 at 8:01am |
IBWD MIke
Posted: 12 Feb 2025 at 8:42am |
Oh yeah. Booked my room the day I checked out last summer. probably drag the 45 and a 73 plow up with me again. Wish it was feasible to remove the wheel weights so I could pull it in more than one class. I suppose I could take the NFE tractor, easy enough to strip 1000 lbs. off of it.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3194 |
Posted: 12 Feb 2025 at 12:33pm |
I have a parts baler with the Overdrive all complete with the OD and related gearbox etc.If someone needed would give them a very good price.Or take the whole baler
dr p
Posted: 12 Feb 2025 at 7:14pm |
There is a thread we started a while back about a bale loader made by hansen. The only one i have ever seen was on a 1/16 model made by the guy out in Arizona who makes those amazing precision models. I think it might have worked ok with a number ten but with a standard rotobaler the guy on the wagon would probably be on the ground by the end of the first round
wjohn
Posted: 12 Feb 2025 at 8:07pm |
You know, I have a Farmhand F11 on one of my D19s. That's not a bad idea... I could build some sort of accumulator for the front of it and gather up bales that way.
wjohn
Posted: 12 Feb 2025 at 8:16pm |
Just put some big old wing nuts on the bolts for tool-less removal and we'll get as many guys as we can to help hold everything when the weights fall down, ha!
wjohn
Posted: 12 Feb 2025 at 8:24pm |
I found the thread of Armand's model and that is neat. In the last post a guy says they had one at Hutch once. I wonder if I can find any footage of it from prior year Hutch videos on YT.
Gatz in NE
Posted: 12 Feb 2025 at 9:30pm |
You know, I have a Farmhand F11 on one of my D19s. That's not a bad idea... I could build some sort of accumulator for the front of it and gather up bales that way. [/QUOTE]
We just used the standard “sweep” on the F11 to accumulate the bales and bring them into the Sandwich elevator, thence up to the hay mow. |
Mark (ECIN)
Joined: 13 Mar 2024 Location: Hagerstown, Ind Points: 27 |
Posted: 21 Feb 2025 at 4:53am |
Is this the type of loader you are discussing?
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 21 Feb 2025 at 6:27am |
I mounted a Hansen loader on my number 10 and used it at Hutch. It did not work to well. The bales fell back into the belts. I gave up on it and it now resides on Gary Agrimison's number 10 engine drive baler which is displayed every year at the Hutch show.
http://lonsallischalmers.com
IBWD MIke
Posted: 21 Feb 2025 at 9:24am |
Lon, you moved a lot farther into Wisconsin than I thought you were! Had it in my head you were going to be somewhere near Ted? You are on my radar if my big goof off trip happens this summer.
wjohn
Posted: 21 Feb 2025 at 6:33pm |
So, that means I must have seen it in person last summer and didn't register it... I must have been too busy learning all I could from the guru of breaking down and hauling Rotobalers on trailers. I'll have to pay more attention this year.
Lon(MN)
Posted: 22 Feb 2025 at 7:25am |
Lon(MN)
Posted: 22 Feb 2025 at 7:27am |
IBWD MIke
Posted: 22 Feb 2025 at 7:31am |
Lon, have a calendar out to plot this summers activities. Need a week or so for the 'goof-off' trip.
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1990 |
Posted: 28 Feb 2025 at 9:00pm |
Theres actually a good chance this baler rolled off the assembly line as a #10. There was a number of balers sitting in inventory at the LaPorte plant that were never sold. When they realized it was a flop they converted them to fast wrap balers, gave them different serial numbers and repainted them to the current colors. Notice it has the #10 axle. There were some leftover #10 baler parts that were assembled as fast wrap balers. Once all of the parts were used up there was no longer a fast wrap option.
Many roto balers have a dent in the hood, it is believed to be from a knot in the twine catching as it got caught in the guides in the roof. I have heard it happen and makes a loud noise. There are a few Hansen bale loaders out there. I have one, it came off a standard baler. Allis-Chalmers did offer it as an option but only for the #10 baler. I'd have to check but I believe there was a guard that could be installed to prevent the bale from falling into the belts. Congrats on a great find! Jim
dr p
Posted: 01 Mar 2025 at 7:21am |
I think those are the pick up"feet" for a number 10 as well
Page 12> |
