WC Final Drive Oil |
KY
Topic: WC Final Drive OilPosted: 30 Jan 2025 at 2:43pm |
Would EP "00' grease be close to the specified 250 weight oil called for in the book for the final drive oil on a WC?
DrAllis
Posted: 30 Jan 2025 at 3:33pm |
Can't tell you. If it was mine the axle/wheel hub bearings would get packed with wheel bearing grease and I'd throw in several tubes of "corn head grease" in the gear case. Probably 6 tubes to a side if I was guessing.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90892 |
Posted: 30 Jan 2025 at 3:57pm |
00 grease has the consistance of apple sauce... That ( or 0 NLGI) would be comparable to the corn head grease that Dr mentioned..
![]() Edited by steve(ill) - 30 Jan 2025 at 4:03pm |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1347 |
Posted: 30 Jan 2025 at 10:13pm |
Would 85W140 work?
That’s what I put in my wd and Wd45 final drive… Never change a WC’s though. |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 30 Jan 2025 at 10:48pm |
i use alot of 00 grease on things here , a lot on the lawn and garden gear boxes it will get were it needs to be in there and stay
DrAllis
Posted: 31 Jan 2025 at 6:24am |
That's the deal with an RC -WC or WF. All they have for a seal around the wheel hub is a large diameter cork gasket that is prone to seepage when oil is used, which is what they used back in the day.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 31 Jan 2025 at 6:31am |
that’s why I have corn head in my WC, its best property is the fact that it goes back to a semi-thick state as it cools and this stops a lot of the seeping that comes when they sit.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
KY
Posted: 31 Jan 2025 at 7:47am |
Yep we packed all of the bearings with grease already. I was not sure if corn head grease would lube that top bearing enough, that is the route we will go. thanks for the info! This has been a 4 year long nut and bolt resto so we wanted to get it right.
KY
Posted: 31 Jan 2025 at 7:49am |
85-140 is too thin for a WC . There is a big cork "seal" that is very prone to leaking
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 01 Feb 2025 at 10:10pm |
It's been a while but I thought a new rubber seal was at one time available from AGCO. I was going to restore a WC many years ago and I investigated things like that when I worked at a dealership. Been 30 years ago though.
Wink I am a Russian Bot |
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1170 |
Posted: 02 Feb 2025 at 12:57am |
I don't remember a lot about our WC. But I sure do remember Dad having a good supply of SAE 140 around to keep her lubed up.
Phil48ACWC
Posted: 03 Feb 2025 at 6:27am |
In my '48 WC I replaced the large cork seals with the new rubber ones. I greased the rubber seals with heavy grease and added preload to the seal by adding a shim ring made from a plastic 5 gallon bucket. I use 85W-140 gear lube with almost no leakage. Working great now for 3 or 4 years. All the brake box seals were replaced along with brake linings about 5 years ago. A WC with brakes that work, rare and amazing!
ekjdm14
Joined: 20 Aug 2024 Location: Alsager UK Points: 987 |
Posted: 03 Feb 2025 at 7:27am |
Wonder how many members read Morse fluently ![]() ![]() |
