417 loader mounting help.
JoshDay94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Topic: 417 loader mounting help.
    Posted: 22 Jan 2025 at 8:26am
Hello. Im mounting the 415/17 loader to my series 4, D17. The right hand bracket that goes to axle hits the traction control linkage and rubs the hydraulic cylinder. I have a hard time seeing how I could get the ubolt around axle too. Can someone please post a picture of how theirs is bolted on. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 8:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 8:31am
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 9:19am
On a 500 series theres a 3/4 spacer between the engine frame rail and loader frame. They were left out when installed on the larger tractors. I dont know about a 400 series.
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 9:22am
Swap sides. U-bolt and angle iron are outside the fender mtg plate, not inside.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 9:32am
Hi Josh
I had a look in an Allis Parts Catalog for the 400 and 500 Series Loaders.
The Rear Mounting Brackets for a D-15 are different from those for a D-17.
For a D-15 the Angle Iron butts up against the front side of the Axle Housing.
This Angle Iron tilts forward at about a 45' angle.
For the D-17, the Angle Iron butts up to the rear side of the Axle Housing.
This Angle is an extension of the Loader Frame itself, and is angled approx. 45' rearward'
I am not familiar with any of that extra Set-up around the R/H Axle Housing that you show and refer to as part of the Traction Booster System.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:02am
Dr. I swapped them out but they still won't clear the fender brackets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:07am
I have the 17 series brackets but it lines up with the mounting brackets for the fenders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:08am
Dr. Are the finder mounting points at different areas on the axle for the series 4 compared to series 1 thru 3?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:12am
Nope. The pre-series 4 doesn't have that TBoost linkage there, but I know the U-bolt goes on the outside of the fender bracket plate. You CANNOT run the rear wheels 100% clear in. They must be out at least 2 inches if not 4 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:22am
Ok, i will move wheels out, but even then if i put bracket on the outside of fender the holes are off from bracket to loader
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:25am
Also there is a gap between the angle and the axle like a 2 inch square tubing could fit between bracket and under/rear side of axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 11:07am
Leave the bolts loose on the tractor/loader side frames and pull the loader out to meet the holes. This isn't like a connecting rod cap inside an engine, precision machined. You have to use pry bars and lineup punches for assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 11:11am
Someone else better get in here. I'm now wondering if there are 3/4" spacer plates between the side frames and the loader frame for a 400-series loader on a D-15-17. I know you don't use them on a 180 on up with a 500 series loader, but must use them on a 175 on down with a 500 series loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 11:24am
The manual only speaks for spacers for the D14. Im trying to get it somewhat mounted to axle between stuff going on at work. I will get pictures more in a min.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 11:25am
I just spent $1900 to rebuild all 4 cylinders so I'm pretty far in depth now for it not to work now 😅
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 11:28am
OK. If the D-14 needs them, the D-15-17 shouldn't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 11:42am
This is with ubolt snug to axle. But im out of threads and can't tighten anymore. They are agco part number for this loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 12:06pm
Id measure between the uprights with the frames mounted to the front of the tractor. If that doesnt match the boom width you would know if you need spacers
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 12:12pm
I think I found the issue. One of the angles are bent pretty good. I put the other side together and it lined up almost perfectly. I was having a heart attack after how much cash I have sunk into this. Will update soon
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 12:30pm
Josh and Dr.
I had a look in the Allis Parts Catalog for the 400 and 500 Series Loaders.
Confirmed that the D-14, D-15, and D-17 all use the same Side Frames and Boom.
Josh has it right, the narrower D-14 requires the Spacers, 1 front and 2 rear, between the Side Frame and the Tractor Frame. Same for both sides.
Then had a look in the Allis TM-328 Operating Instructions and Parts Illustrations 400 and 500 Series Loaders.
On Page 10 is an unusual Picture.
Fig. 7 is tagged as 417 R/H Rear Frame Mount - 'U' bolt is inside the Fender
Fig. 9 is tagged as 517 R/H Rear Frame Mount - 'U' bolt is inside the Fender
Wouldn't the 517 have to be on a Ser.IV with the Live Hydraulics, like Josh's?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 12:38pm
Maybe I'm cornfusing a 500 axle connection with a 400 axle connection. When the U-bolt is outside the fender bracket, there is a small angle iron "clip" that slides on the U-bolt to keep it from working its way towards the rear wheel. If the U-bolt is truly inside the fender, this wouldn't be needed. If the U-bolt is indeed to be on the inside of the fender plate, the TBoost linkage may have to be removed ?? to make room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 1:23pm
It not only hits the linkage but also the 3point cylinders. So it has to go on the outside of the fenders. I was hoping for a 500 series loader but for $350 for this 417 I couldn't pass it up.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 2:36pm
pic out of loader operating instructions (form tm-374)
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 2:50pm
Josh
As I understand it, you actually got more being a 400 Series.
The L/H Frame Mount of a 400 Series has the Hydraulic Oil contained inside the structure, along with the outlet at the bottom to feed the Front Mounted Pump, the return line fitting higher up, the Oil Fill Spout and Cap at the top.
Also connections for the Bucket tilt and Boom Lift Valves.
The 500 Series would not have any of this extra because of the Live Hydraulic along with a pair of Double Acting Hydraulic Control Valves as part of the Tractor.
Still can't figure out why the Ser.IV has the Traction Booster Set-up like yours.
Allis D Series Traction Booster System started in 1957 with the intro. of D-14 and D-17.
It had to be modified to suit the introduced 3 pt hitch, but still the same working principle.
Perhaps another Forum Member has a D-17 Ser.IV with a 400 or 500 Series Loader and could comment and / or provide pictures.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 3:00pm
No spacer needed for a 417 loader, two things come to mind, one something is bent or it's badge wrong, I would guess it's bent or maybe the angle that the rear mount goes on has been broke and rewelded. I put a 415 on my D17-1 and had to rework the mounting brackets. When you run out of threads on the ubolt clamp put some more washer or something to be able to pull it down further and like Dr. said leave thing loose until you've every bolt installed. HTH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 3:14pm
Gary, the D-17 IV has live hyd and the other D series don't.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 3:38pm
Hi Kenny
Thanks for posting that picture. It is very similar to the one I was looking at.
But it is different. If you look close you can see a bit of the 'Live' Hydraulic Pump hidden behind the Loader Frame Upright.
Also it looks like you can see the Traction Booster Linkage mounted to the Axle Housing.
That is the Picture Josh needs.
Am I seeing correctly, the 'U bolt' is between the Fender and the Wheel, and the Traction Booster is by itself inside the Fender Bracket?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 3:48pm
Traction Booster linkage and the lift arm cylinders are unique to the D-17 IV, One-Seventy and 175 tractors.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 4:12pm
Here are some pictures from the owner's manual that may (or may not) help.
Edited by Brian G. NY - 22 Jan 2025 at 4:20pm
This page was generated in 0.641 seconds.
