Allis b water pump
Hardwater000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Topic: Allis b water pump
    Posted: 21 Jan 2025 at 7:17pm
When I took water pump off while painting, reinstalled with new gasket.now have a leak appears to be around the gasket but was wondering if the bolts run in water and need to have silicone or similar on the threads and maybe a copper washer. Book really don't show me what I need to know.
LittleB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LittleB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 7:29pm
There is indeed One bolt that enters the water jacket. i believe it is the lower bolt to the left while you are facing the engine. it needs sealant on this bolt when you replace it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 9:18pm
That's what I was wondering.i may be pulling it apart again
And I think it has a copper washer to but the paint is covering it.
This page was generated in 0.057 seconds.
