Diesel or gas
D171958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Topic: Diesel or gas
    Posted: 21 Jan 2025 at 8:40am
Wondering if it would be better to put a 226 gas engine in a d17 or a 262 diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 8:56am
What chassis do you have now ??   If it is a GAS chassis, you must stay with a G-226 gas engine. If it is a DIESEL chassis you must stay with the D-262 diesel or G-262 gas engine family. The clutch shafts between the 226 and 262 families are different lengths. The side frames length are also 3 inches different and the hoods, etc.
Edited by DrAllis - 21 Jan 2025 at 8:57am
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 9:17am
OK, just HOW do you guys keep all this information in your heads ????CryBig smile
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 9:52am
   Mad genius's.    Navel maneuveringWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 11:43am
So to engine swap it it will be a big deal.
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 12:06pm
Yep, lots of differences between the two. Even the lower steering shaft, and the fuel tank, radiator, throttle linkages, etc, etc…. Additionally, the 262 diesel has quite a few inherent problems that are costly and time consuming to fix, and parts availability is a real problem for them also.
Edited by RedHeeler79 - 21 Jan 2025 at 5:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 1:41pm
D171958, you have us all wondering if you even have an engine at all ??
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 5:14pm
I too marvel at this! Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 5:45pm
No I don’t have an engine for it seen it on Facebook it’s a gas series one I thought it would be pretty cool to put a Diesel engine in it if it was easy and cheap Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 6:14pm
Easy? Nope.   Cheap ?  Not a chance !!
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:06am
I saw a guy put the diesel side rails hood etc on a 226 gasser for tractor pulling.
In Nebraska, not sure how much of an an advantage it would be ???
Thought it was interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 10:10am
Moves the front wheels out 2 3/4" inches making the nose a little heavier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 2:09pm
Always wanted to make my old D17 series I diesel into a 6 cyl 262 gas puller.
Most places would not care but thier's a few antique rules book pulls that would not allow....
So I just made my 4 cyl gas big cube....
I guess there's gotta be some rules...
Edited by Macon Rounds - 22 Jan 2025 at 2:41pm
