WD crankshaft pulley
SteveRogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveRogers Quote  Post ReplyReply Direct Link To This Post Topic: WD crankshaft pulley
    Posted: 18 Jan 2025 at 11:07am
I think it's my crankshaft pulley that is broken.  Fan and power steering belts aren't turning when the tractor is running.  Looks like a cast iron piece is broke out of part next to where the crankshaft comes out.  How big of a job is it to get to this piece? Any tips or suggestions on how to get to and fix this part would be appreciated.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 7:23pm
You really need to disassemble it to see actually what you need to do. If it is a Char-Lynn pulley causing the trouble you might need to get creative on a solution or buy a new double pulley all together.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 9:11pm
To get to the Pulley:
   drain the Rad
   remove the Hood
   remove the Rad Cover Shell
   remove the Rad, don't forget the 2 @ 3/4" socket bolts that are accessed
      from under the Rad.
   Now I think the Crankshaft Pulley should be accessible.
   G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 7:21am
I would be very concerned about what condition the crankshaft snout is in after this kind of failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveRogers Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 2:59pm
The crankshaft pulley does not appear to be broken in any way.  But there is another part that goes over the top of the pulley and has 4 set screws that attach it to the pulley. What is this part for and how I know what should be the tolerances should be or how should it be adjusted to the crankshaft pulley?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 9:34pm
That is the Char-Lynn pulley. It is an add on to spin the power steering pump.
A total disassemble is in order to see what parts are salvageable. If that pulley came loose, there is a pretty good chance it is wore too much to hold onto the crankshaft pulley.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 8:01am
Steve-  I sent you a PM-  I'll be back in the QCA this weekend, I can come over for a look and help you find a solution.
