DEF junk
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Topic: DEF junk
    Posted: 15 Jan 2025 at 4:54pm
Just read that Oklahoma is proposing a law to protect farms and businesses from undue burden caused by the new diesel engines. Just had 2 examples here today, we have had temps from 0 to 10 degrees out with -20 windchill. Friends fairly new Ford pickup, the cable that heats the hose for the fluid failed and had to be replaced. And talked to a guy from the coop in line delivering corn today. Monday night he said his freightliner went in regen mode and after running it quite awhile wouldn't make enough heat to finish a regen so they had to take it to the dealer. I wondered about that last week as the line at the ethanol was a 1 and a 1/2 hour wait, and you have to keep moving ahead. Do they let the trucks idle or shut them off? My old Freightliner just sits and idles at high idle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 5:10pm
When I was hauling petroleum products - big sign at GATE on regen of tractor , must be outside of refinery property , NO REGEN on or near any area on property or their frontage road to gate .
  Was bad enough when company filled their bulk tank for tractors and it went below Zero and filters gelled - of over 150  tractors .  I got back to yard after buying 40 gallons of #1 as my tanks were low enough .
 The full idea of a water based fluid and in a area of freezing temp is another government SCREW UP of some Desk Jockey who doesn't even know how to hold a steering wheel in a Class 8 truck without getting a nose bleed from the height to cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 6:01pm
Diesel engine freedom act is the law proposed. I hope it makes its way to other or all states.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 5:40am
More states and industrial side suppliers getting on this train. Does so little while costs so much not just initially but constantly. A running joke as to how much it cleans up the air which is minimal at best.
Engine companies showcase EPA “Estimations” of what level of exchange and conversion these garbage piles perform. Is on the engine company sites, 20-30% particulate reduction which means 20 is typical 30 is likely from a brand new distance driven road tractor in the 11 western states in the Summer. Produces water and Co2 from the CO in exhaust is a flatout lie, the water comes from the DEF not the engine exhaust. As well as with the auto systems even on Gas the US could be witnessing 35-55mpg gasoline cars instead of 22-35 and 8+ instead of 6+ on diesel powered road trucks. Saving Fuel should be priority one not burning more claiming polluting Less, that math does not compute.
VW proved this point with their cheat as the machines passed Drive By emissions checks achieving 45mpg on diesel, was a insider that squealed as to the programming mods to attain mpg and still meet air quality that cost them a bundle. VW in EU achieve close to 50mpg on diesel, 40-45 on gas and 2/3 that here. Science can be fascinating as to finding idiot flaws.
Edited by DMiller - 16 Jan 2025 at 5:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 5:54am
May not be viable yet will throw these numbers down.
My rebuild C15 Cat 15liter engine at 70mph at a minimal load achieved a phenomenal 8.7 mpg on cruise on a fresh not completely broken in rebuild. With a livht 13,800# load same travel path at same speeds attained 8.1mpg and I am logging these trips records. The same model can I drive at work has a dash indicated mpg value where is geared similarly and has a 15L cummins X15, cannot break 5.9 mpg out of it no matter the operation parameters. Exhaust after treatment cuts in INJECTS Fuel to add heat in the System to make it function, wastes high dollar fuel and DEF trying to eat what is NOT there so adds enough to have something to consume.
Post Options Post Options   Thanks (2) Thanks(2)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 12:00pm
yes, but science stands in the way of 'someone' making their 10%Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 9:21pm
Ah but don't forget the carbon capture pipeline that will transport CO2 from Ethanol plants to N Dak to pump it underground (no problems there known) . This all as Ethanol is good for the environment as it cuts down on petroleum use and raises corn prices .
 Years back CARB in Cal required diesel (converted to alcohol) compression engines in LA basin on trial run - cut down on Diesel Petroleum exhaust matter - but raises FORMOLDAHIDE levels in air to a point it was detrimental to health of animal and human nearby .
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 4:08am
Exactly my issue with the Automotive EPA types. Try to palm off can Destroy base elemental emissions materials, violates physics and chemical laws, develops and implements mechanisms with minimal testing ending up are worse for environment and more costly than just allowing a Minuscule Level of nothing to exist. Create far more problems than reduce
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 10:42am
Anyone  NOT get their DEFride started in this 'cool' weather ??
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 11:48am
Untill they started putting diesel in cars and pickups diesel fuel was a byproduct and prices were cheap. I remember in the 70s paying a $.25 per gallon
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 12:04pm
Yes  Wink but what was the gas price? Maybe .30 to .35 cents/gal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 3:10pm
Fuel oil has always been a left over of making lubricants, same as Gas. Lubricating Base stocks, Paraffin based lubricant greases, heavy oils. Then solvents as gas, and finally the lightest oils and gases.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 9:38am
I know around here diesel was always cheaper than gas until the 80's when they started using diesel engines in cars and pickups
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 10:45am
Now that the diesel in cars is almost nil, I don't understand the as much as a dollar more for diesel than gas. I don't buy diesel in town, so I don't track the price fluctuations. But very common for diesel to be almost a dollar more than 87 octane gas. But at times  on par with 92 octane gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 11:55am
Simple, MORE trucks on roads, idiots from Foreign countries driving here, no concern how much they use. Add to that nearly all the NE US is still on Fuel Oil Heat IE No 2 fuel oil or diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 3:47pm
No doubt! Talked to driver dumping fuel at Loves south of Indy. Said 8 tankers a day. That's just one T stop! Can't fathom the gallons in a day across the US. Gasoline is the by product of making enough diesel hence the price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 3:55pm
What boggle my mind is that semi truckers say 8 MPG is GOOD !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 4:49pm
that is the falicy.... add the DEF and get 20% reduction in smog, but get 30% reduction in MPG.... WTF !! .............Better to go for HIGH EFFICIENCY and it will be CLEAN !!
Same for cars.. You got 3.5 liter engines getting 20 MPG in a pickup truck !!  Why add all the BULL CHIT !!..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 6:29pm
My 05 KW gets 8.1 to 8.7 documented even as is running light load. HOWEVER, the 15 L engines at work often will not make 6mpg empty. Aftertreatment systems pumps fuel into the exhaust to preheat the catalyst to get reaction. What a waste of effort time and fuel.
VW was getting 45mpg Diesel and over 37 routinely on Gas until EPA had whistleblower note the programming alteration. After restored to US EPA regs the cars barely got 38D and 30G.
Makes ZERO Sense to burn More fue and actually quote make less emissions, absolute BS.
Edited by DMiller - 24 Jan 2025 at 6:36pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 6:34pm
GEES DAVE.... there a 10,000 guys at the EPA that are HIRED to make STUPID RULES !!!  What do you want to do with them ?. .... Maybe put them in line with the DEI Supervisors ??.... I hear McDonalds needs more french fry cookers !!  Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 10:56pm
5-6 is normal....could do better (but not a lot) but I don't drive for fuel mileage.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 5:51am
Guess Scott Miler still don't have to feel bad about his 8 miles a gallon Wink
Never a truer song sang there "build a big engine, make it run on bullchit put it down the highway buddy it'll never quit"... Maybe that's the new job for those DEI and EPA dudes, stick 'em at truckstops and have them talk into the tank...
Edited by ekjdm14 - 25 Jan 2025 at 5:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 6:30am
EPA and DEI, Speaking BS into Tanks!!! Needed that laugh this morning!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 6:42am
A little More Research.
33,800CF of Natural Gas to make ONE Ton of Urea, that is dispersed as primarily Fertilizer and as the additive base for DEF, NOT Including the Gas used to create the .57T of Ammonia used with Urea to produce DEF.  3(28%)to just under 4(32%) Lbs of Urea to One Gal of Water for DEF varied solutions.  So a Ton of Urea only produces around 500 gallons of DEF, that has a Shelf Life of LESS THAN 6 mos.
How Many THOUSANDS of Gallons of DEF are consumed Daily?  And the Ammonia NOT absorbed in the Conversion Process is FREE RELEASED to Atmosphere, Damage From? remains Unidentified or even Investigated.
Edited by DMiller - 25 Jan 2025 at 6:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 7:08am
FIVE MPG !!!!! That is CRAZY, really, I never knew is was sooooo low.
How the heck can truckers make a 'living wage' ?
Now I'm wondering how long I could heat my house using the NATGAS used to make 1 jug of DEF.....
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 8:11am
it is good. It’s fantastic. Put the weight transported in as many F 150’s that it would take and see what the weight per gallon works out to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 8:14am
it just seems that 'they' should be focusing on getting semis more MPG than cars as trucks haul 99.44% of all goods, everywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 8:49am
DMiller you are right the EPA comes up with the solution to a problem but doesn't consider the long term problems the solution created. It's going to end up being the same thing with wind and solar. This has been discussed before.
Edited by DanWi - 25 Jan 2025 at 8:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 10:19am
The members at EPA have but one consideration as to Emissions, REMOVE ICEngines.  Agenda Based ONLY.  Make them ever more expensive and harder to deal with and FORCE Change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 11:50am
kinda funny, 'remove ICEngines'
Canada/Ontario is spending BILLIONS for li-ion battery plants YET, Ford USA has told Ford-oakville to re-re-tool the plant from battery powered mustangs for gas/diesel powered F250/350 pickups !!!!
