WD45 Shifter Woes
jyanna View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jyanna Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Shifter Woes
    Posted: 14 Jan 2025 at 9:30am
My WD45 has had a difficult time shifting.  It can take some time to get it into the right gear.  The lever pops out occasionally, but it is no problem to get it back in.  I don't know if the problem is the shifter, the forks or something else.  How do I diagnose this?  Is there some place I can send the assembly to get it redone?  Any other ideas?  Thanks in advance!
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 9:49am
Sounds like the tip end is badly worn. Can be welded up and ground down. Has been past posts with dimensions. I don't know how you find them.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 10:01am
Chris, Sugarmaker has a bunch of stuff on this. I did a search, click on his name then 'search member posts'. Shifter was the only word I used.
That ought to keep you entertained awhile!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jyanna Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 3:21pm
Thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 5:01pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 8:14am
Check the post here on WC shifter. Maybe they can help you as well. Smile
