Insulation product warnings
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Insulation product warnings
    Posted: 12 Jan 2025 at 4:35pm
Having to undergo Fire Fighting training at the Nuke we learned to keep our SCBA units ON regardless the fire being knocked down. One was for potential of a relight with heavy smoke the other combustion product gases auch as burning Wool that releases Hydrogen Cyanide.
The New Craze in home insulation is none other than Wool, are no cautions or warnings that I have seen as to the problem of Poison gas release in a fire, none nowhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 2:32am
Handled Chlorine gas for over 30 years as used in Chemical Milling operation .
At times we had over 17 Tons of it setting on loading dock and in handling room .
Used a SCBA when changing tank connections - then house air mask instead .
When went to Emergency Response Team Incident Commander - it was required to suit up to Level 2 any time there was a leak .
 Last leak I responded to - wet chlorine interacted with titanium diaphragm in reduction pressure regulator , creating a fire , had City Fire Dept respond . They would not enter area as Chlorine involved and their responders from that station were not Haz-Mat trained for gas . Had to go Level 1 to check if any fire in room then - they stood by to get clearance to enter after all system valves were isolated .
 One never knows what one is going to find out what things will injure or kill you sometimes - who would thing WOOL is now a health hazard !
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 1:30pm
May be a dumb question but what is the wool you are talking about? Is it some chemically formulated fiberglass like stuff?. Can't be sheep's wool or, can it?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 4:55pm
Would they be talking about rock wool insulation, I wonder?  It's a popular insulation material but more expensive than fiberglass, and contains some recycled materials.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 5:53pm
The most common occurrence of cyanide poisoning
Several reports have shown that persons admitted to hospital due to fire accidents may have been exposed to carbon monoxide (CO) as well as cyanide (CN) [1-3]. In fact, it has been reported that the most common source of CN poisoning in humans arise from exposure to fires [4]. In fires CN is developed when the temperature reaches 315°C (600°F) and is released from the toxic fumes in the gaseous form, i.e. hydrogen cyanide (HCN) which may then be inhaled by the victim [1]. HCN is developed from an incomplete combustion of any material containing nitrogen [5] such as plastic, vinyl, wool or silk [6]. It is worth noticing that when cotton burns it develops 130 μg HCN/g, paper 1100 μg HCN/g and wool 6300 μg HCN/g. One has to be aware that HCN is still produced when the fire is only glowing embers [7].
Edited by steve(ill) - 13 Jan 2025 at 5:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 5:58pm
who would have guessed ...
Wool contains approximately 10-12% nitrogen on average, making it a good source of slow-release nitrogen for soil when used as compost or fertilizer;.
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 9:09pm
Well, I always did prefer cotton....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 9:21am
California will probably ban sheep as deadly hazard!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 1:27pm
That would be tough with all the Mutton Head Sheople out there!!!!
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2025 at 5:36pm
Steve{ill], That helps explain a video a watched the other day about a Gardener in Scotland using Sheeps Wool as a bedding / Fertilizer in her gardens. She also claimed the wool she is using is deemed worthless in Scotland due to the abundance.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2025 at 12:14pm
     just go buy someting made of wool, it becomes vastly more valuable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2025 at 2:31pm
Sheep lie!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2025 at 3:12pm
BAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA hahaha....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2025 at 5:32pm
Baaaaah, DaaaaaDy!!
This page was generated in 0.199 seconds.
