Ran When Parked...
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Ran When Parked...
    Posted: 06 Jan 2025 at 8:46am
I bought this engine (cheap) mounted on an old Allis-Chalmers hay blower. Cylinders #1 & #4 have large chunks broken out of the sleeves, I presume caused by water freezing. I'm hoping I can get the sleeves out without damaging the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:06am
Pretty Ugly
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:11am
scuff and buff, she'll fire right up !!!!
ATF/ace 50:50  and some patience. OK, maybe a lot of patience.
nice 'winter project' though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:37am
Pretty Ugly
Yup.
I cannot recall ever seeing worse Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:38am
Might take several winters!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:42am
at 71 I'm not in a hurry....though it'd be nice if ONE of my 2 big toes healed up soon...
HoughMade View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:55am
If it were me, I scrape an vacuum all the loose chunks out and if I could get a fluid to sit in the cylinders, I's use an actual rust remover- Evap-O-Rust, not some mix of anything.  Then, when as much rust is gone as possible, load it up with some sort of penetrating oil and you may be able to get it disassembled without too much stress on the block.
I used this method on a "B" engine with 2 rusty cylinders and it runs great years later with the pistons never having been taken out.  I get your engine isn't going to do that, but getting rid of the rust will help it come apart.
1951 B
captaindana View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 10:32am
Good luck Les. The G I had once upon a time ran when parked also. Looked just like yours! 😫
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 10:40am
Wow- junk it and get a different one!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 11:08am
Might be a great candidate for an electrolysis soak (e-bath). Anyone on here ever do an entire engine into a e-bath? How are its head, valves, intake, exhaust manifolds ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 11:20am
Les Kerf, is your engine a D14 149cu in from an AC 30L long conveyor or 30S short auger blower?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 1:54pm
I thought it might be a 125 CE engine... but your right, possible a 149..
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 6:54pm
Les, is that the blower that sold in tioga county pa in Sept?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 7:12pm
... How are its head, valves, intake, exhaust manifolds ??
Pretty rough, not sure what will be salvageable.
I am not knowledgeable enough about blowers to say but it doesn't have an auger. The engine is a 125 for certain, hand crank only.
I will try to get some more photos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 7:22pm
No, this one has been sitting on my neighbors farm here in northern Idaho for many years
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 7:24pm
I actually have different one that looks like it will be much better, although it too is stuck. We got it to move about a half turn today
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 7:36pm
son got a CASE 530 backhoe that was setting in the corn field for 10 years with not stack on it.. ( 15 years ago)... I rebuilt the motor for him... Looked very similar to that one.. Once you get the pistons and crank out and pound out the sleeves.. you got the bare block... If not crack, it will clean up OK.... NEW KIT fixes about 90% of those problems ! ... I had to get the crank turned .020 to clean it up due to rain water in the crank case..
55allis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 2:00pm
My 60a combine engine looks just like that…
In the process of getting the sleeves out to inspect the block.
plummerscarin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 3:42pm
Looks like the one in my WD project with 2 less cylinders. After complete disassembly the block cleaned up nice and the crank was turned .010ā€ under. New engine kit is making it look real good so far.
DSeries4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 4:34pm
My 59 D14 looked similar to that when I got it.  Soaked it for several months and pounded out sleeves and all.  Both the crank and cam were still good.  Put a major OH kit in it and rebuilt the head.  She runs 100% now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 9:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 10:03pm
Bottom View
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 10:24pm
brass, copper, and aluminum are negatively affected by electrolysis, it's also a line of sight operation, anode needs to be able to "see" all nooks and cranny's to clean them, would be hard on an assembled engine
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Alberta Phil View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 9:41am
I like a challenge, but I might give that one a pass!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 12:05pm
Here is my Model 60 Combine engine, just got it freed up yesterday. MUCH better looking on top, have yet to pull the pan.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 2:38pm
My bottom end looks pretty nice other than the crank seems to be a bit scored. Hoping it will be fine for the combine being I will have more into the engine than it’s worth.
Edited by 55allis - 08 Jan 2025 at 2:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 10:55am
Les Kerf, just wondering how your 125 engine is coming along? Thanks for all your follow up photos & answers.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 3:42pm
I fear that is more than electrolysis can handle from my experience.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 7:29pm
just make sure the valves seal and replace the oil sump pickup pipe that is probley cracked and it will run
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2025 at 7:22am
I am setting the blower engine aside for now and focusing on the Model 60 combine engine as it is in MUCH better condition.
Combine bottom view:
Everything looks so good I am not even going to remove the bearing caps.
Combine head:
A basic cleanup and valve job should suffice.
Combine Head #3 Cylinder:
The intake valve seat has been re-worked and machined into the head somewhat deeper, maybe 1/16" or so. Not easy to see in the photo.
I am not going to stress over it.
I am planning to re-seal everything and set it aside. I have a derelict Model C in which I hope to install this. That will warrant a new topic.
