D14 steering seal
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D14 steering seal
    Posted: 24 Dec 2024 at 10:43pm
Parts I need for my front support finally came in. The seal for the shaft retainer was a concern because it looked like a sweeper(felt)on top of a seal. The book only calls for 1 oil seal. As I described this to Brenda, she showed only 1 seal and it wasn’t nearly as thick as the original with no felt sweep built into it. Only seal available for it. Once the old one was driven out it is clear that it was all one seal and 2-3 times as thick as the new one. My concern is, this seal was driven down on a shoulder which made it flush with the retainer face. As it was designed. With the new one driven down on the shoulder it will be far below the retainer face. Should I order another seal and stack it on top of this one and drive it flush with the retainer face? My only other choice is to find a NOS seal from someone. Suggestions please
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 12:29am
Are you referring to 229967 seal
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 5:31am
Good Morning Robbie and Merry Christmas
I can’t speak to the seal for the steering but I remember the same issue on the rear pto seal on a D14 or 17 and ended up doubling the seals and worked fine.
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 7:49am
I always double up on the replacement seal have done 15 17 19 no problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 8:40am
Ii did the double seal trick for one rear axle...
..wished I'd both back then....sigh
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 6:20pm
Yes Mike, with 70 in front of it on the AGCO site.
I will see if anyone has a NOS first in the next few days, if not I will double seal it. Thanks everyone for responding.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 1:14pm
I would double seal it, 2 better than one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 8:54am
I will see if ours are old or newer style
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 9:29am
Thanks Mike but I’ve already ordered another seal to double it. I didn’t hear back from anyone that may have NOS.
