Here's What Happens to a WD-45 w/ No Oil Pressure
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Here's What Happens to a WD-45 w/ No Oil Pressure
    Posted: 06 Nov 2010 at 8:51pm
After trying some "wish-ful thinking" solutions such as putting in heavier oil and trying different oil filiters this is what ended up happening----A complete engine overhaul as well as putting a new clutch in since the engine is out.  Should be exciting to get this tractor done and back together.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 10:42pm
My Dad's WD is heading the same way... oil pressure drops down to next to nothing after it warms up. Good luck with your overhaul!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 11:27pm
Don't forget all new cam bearings and check out the spring in the oil pressure relief.  My WC had a bunch of washers behind the spring so I'm thinking it was short of pressure the last while it was work about 35-40 years ago. No washers and good oil pressure now with a reground crank and all new bearings in her. I hope you got the tube in the filter housing too.
Edited by CTuckerNWIL - 06 Nov 2010 at 11:30pm
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 8:55am
I need to overhaul a gleaner E 226 engine.  The combine's last owner did not keep the intake hose from the air cleaner in good maintenance.  Excessive fuel & engine heat melted the rubber hose at the bottom where it connects to the carb.  Dirt got in the air and now the engine runs, but smokes like mad.  How hard is it to overhaul these?  I already have a set of M&W pistons, rings, & sleeves that I purchased sometime back from someone on this site.  What will a set of bearings & gaskets cost me - ballpark figure?  Will I also need to rework the head?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 9:03am
Valve guides and valves will be worn too. Probably at least $60 for gaskets, $100 for mains and con rod bearings. More for camshaft bearings.
Gerald J.
cougar766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cougar766 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 11:09am
hey Steve whats the 66 series IH in the back ground of one of the pictures
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 1:25pm
Gerald J. we need to do some mail order trading .I can get cam bearings for 20.00 the mains are 200. In TN
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 1:35pm
 can sell another engine can hear run  1-800-254-3116 for more  i nfo.
This page was generated in 0.193 seconds.
