190xt hydraulic fluid leak around steering |
Allis Eli
Topic: 190xt hydraulic fluid leak around steeringPosted: 13 Dec 2024 at 9:41am |
Hey Everyone, Had a question on my ac 190xt. I was feeding a hay bale and the tractor suddenly started pushing hydraulic fluid out of the steering column. My 190xt has a cab and in order to remove the hood you would need to remove the cab. How hard of a fix is it to stop the leak?. Is it just a Oring or?
Thanks |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 727 |
Posted: 13 Dec 2024 at 5:11pm |
We had a 190xt. Started it up after lunchone day and fluid started pouring out of the steering collumn. Got the mechanic out to it started it wasnt doing it any more. Never did that again. Go figure
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
DrAllis
Posted: 14 Dec 2024 at 6:31am |
Quad seal on the steering orbitrol needs replacing. Hood has to come off I think I could do one without disconnecting the four hydraulic hoses from it. Only remove the end cap and replace the quad seal and anything else right there. Do NOT disassemble any further than the end cap plate. Seal kit from AGCO and some parts you won't use.
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 904 |
Posted: 14 Dec 2024 at 8:03am |
Not sure what kind of cab you have but I had a Laporte cab and I took off the top steering cover, then I took off the exhaust stack and the air pre-filter stack, took off the nose grill, and was able to remove the hood without removing the cab or even loosening it up.
DrAllis
Posted: 14 Dec 2024 at 8:38am |
I've never had to remove a cab either. Sometimes the hood can be slid forward a couple of inches and drop down at the rear and then up and forward with the front of the hood. Exhaust pipe and instrument panel get removed first.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2484 |
Posted: 14 Dec 2024 at 12:13pm |
The last one that I did,I was able to get the 4 bolts out that hold the orbitrol to the steering column. I then swung the orbitrol down and out the right hand side. I obviously had to remove the right side panel,but I did leave all of the hoses attached.
Alvin M
Posted: 14 Dec 2024 at 1:10pm |
Like Lynn said that is how I do them
jdeere562
Posted: 14 Dec 2024 at 2:04pm |
Very likely a steering hose.
DrAllis
Posted: 14 Dec 2024 at 2:16pm |
A steering hose doesn't pump oil up thru the steering column onto your lap.
jdeere562
Posted: 14 Dec 2024 at 2:28pm |
Folks are often very vague about leaks. Just pointing at an area to check.
Allis Eli
Posted: 15 Dec 2024 at 6:32pm |
thanks for the advice everyone, I will order and install the seal
