D-17 (IV)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Topic: D-17 (IV)
    Posted: 06 Nov 2010 at 7:11pm
Anybody have pictures of the toplink brackets on the D-17-4 tractor?  I know that the earlier ones had a bracket, that went under the seat, and attached to the bolts on the front of the diff, but didn't the series 4 have a drilled and tapped set of holes on the back of the diff?  Memory is a little fuzzy on this, CRS is kicking in!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 7:24pm
I have extra angle brackets for top link on a series IV, not needed, will sell, or locate a cast top link bracket from 170, 175, 185. All are secured with 4 capscrews
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 7:32pm
I'm looking for one also!! How many do you have? Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2010 at 7:58pm
The series 4 has a whole different lift arm housing that has a place to attach the top link. Any older D17 has only two 3/8" bolts that retain the PTO shield and up over the top to the 1/2" seat bolts.....that's all there is.
This page was generated in 0.052 seconds.
