Suggestions on Adding a Hydraulic Valve on a WD
banjojelly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Topic: Suggestions on Adding a Hydraulic Valve on a WD
    Posted: 26 Nov 2024 at 11:47am
Hello. I usually frequent a different tractor related forum, but most of the tractor guys have left and it is mostly lawn and garden stuff now.
I have a WD with a loader that I have been using for small jobs around the house for about 8 years now. The large loader tractor and Kubota skid steer that we use on the farm are only about a mile from my house, so I can grab them if I need them, but having the WD around for moving stuff is pretty handy.
My issue has become that my hydraulic lever has gotten to the point where it will no longer stay in position. I have tried pretty much everything I can do to make it stay put. It not just a creep. It either wants to be full pressure up, or drop. I am not going to waste a bunch of money rebuilding the selector assembly. The hydraulics are strong. I would like to just plumb in a spool valve and run my loader from that. I am not that familiar with the AC high pressure/ low volume system and it only needs to be a one way valve on top of that. My loader is a trip bucket.
If anyone has ever done this before and could steer me in the right direction to do it as efficiently and cheap as possible, it would be much appreciated.
Edited by banjojelly - 26 Nov 2024 at 12:27pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 1:27pm
A simple no cost way to check out if the problem is the packing on the piston in the rams.  Lift the boom up and let it drop a number of times. Put your hand on the ram, if it is much warmer than surrounding metal it is, it is the ram not your control valve. If the seal is bad on the piston of the ram oil leaks past and the friction creates heat.
I also use to worry that the control valve was leaking in situations like you have.  Most times it is internal seals in the ram, and no oil is leaking to the outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 1:38pm
If you are referring to the lift cylinders on my loader as being the rams, then I know they are not the problem. I honed and re-cupped them and replaced the wiper seals when I got the tractor running. They will hold position if the engine is off.
If you are referring to something else as being the rams, then you will have to elaborate for me.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 2:30pm
The friction block on the lift lever is worn so the handle does not stay in position.  You can get a new friction block from Steiners or DJS.  Pretty cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 2:39pm
Sorry, I guess I didn't explain it very well. Even if I hold the lever in one position, it still will not stop moving. I even tried clamping the lever in place to the quadrant with vice grips but it still would either be dropping or raising. I feel like it is something further into the valving other than just the lever itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 2:46pm
Tractors hydraulic pump isn't set for "HOLD" position work. Read the decal on the side of the battery box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 2:52pm
I dont have a battery box, let alone a decal. This is a working tractor, not a barn queen.
I guess I need to rephrase my initial question. I don't want to keep messing with the lever set up anymore.
Can anyone tell me how to add a hydraulic spool valve to a WD?
Thank you.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 7:30pm
you still have get the pump fuctioning correctly  to run extra valves and remotes  i have an extra valve and remotes on my wd   i still use the lever on the quadrant for the lift arms and the one factory remote but i dont run my pump preasure continus if i dont have to .     i have  a permant 5000 psi guage on the top of my pump for a referance , and i seperate the two systems with a diverter valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 8:10pm
So you dont just leave the pump on and let it dead head against a valve? Is this to prevent heat build up or does the pump not bypass internally at a given pressure?
I am not using the rear lift. I have a counter weight box permanently mounted on the rear anyway. I really on need to be able to run the loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 8:23pm
Do you have a manual for the tractor?  The directions are in there for setting up the pump and the linkage.  You need to have the linkage set up for 'Hold'.
After you get this set, you'll have NO problems using it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 9:30pm
Yes I have a manual. In order to make it work correctly, I would have to replace a lot of worn out parts that are not worth replacing. We have 5 WD's on our farm. None of them have hydraulics that will hold anymore. I am sorry if I seem rude, but I am not interested in continuing to fight with the worn out quadrant lever. Even if it was functioning perfectly, it is not a good set up for a loader, especially when you have to use the hand clutch in order to fake live hydraulics.
I am only looking for help on how to put a valve block on it to bypass the lever. My hydraulic pump is strong, it is just the valving and lever that is worn/ broken. If everyone else wants to restore theirs to perfect factory condition, be my guest. But this one was $600 with the loader. I am not wanting to restore it, I am wanting to use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 10:30pm
Any "add-on" valve to raise your loader up/down/hold will be rated for 2400 psi. Your tractors pump, if in great condition, is 3400 psi. So, right off the bat, your lifting power will be drastically reduced. Maybe that doesn't matter. You will still have to use the tractors worn out LIFT/LOWER lever to turn on the pump and to shut it off when hydraulics aren't needed.  And, whatever you wind up doing, the hand clutch will still be required.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 11:23pm
Ontario tractor YouTube channel added a spool valve so they could run their round baler. That may be what you want.
Link to the battery box decal
That diagram shows which bolts to twist to get the action you want. Search for hydraulic decal if the link is bad.
That's cheaper than a spool valve.
Edited by jvin248 - 26 Nov 2024 at 11:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 11:24pm
Where does the 2400psi rating come from? A quick look at single block valves and I see PSI ratings from 3000 to 3625. I am probably going to try and scavenge one from another machine, but that seems reasonable.
Can the pump not stay on if a valve is being used to control it? I guess I don't understand why the pump would need to be off if a valve is installed. The hydraulic pumps on other tractors run all the time. The power steering pump in your car or truck runs all the time. They just bypass internally. If I can just leave the pump on and let it dead head at the valve, then the quadrant lever is not necessary. The only thing I can see that turning the pump off on the factory system does is allow the fluid to back flow to use gravity down. If I had a valve, I could run the return side back to the pump sump, if I knew where to tie into it at.
I am not claiming to know exactly what I am doing. But I have been farming for 25 years and teaching high school shop for 16. I have training as a machinist, although I did not pursue that career. I do know a little bit about machinery. The AC system is just different than the Farmall and Ford and of course any of the more modern equipment we are using like our Magnum series Case's. Before I tore into it myself, I thought it wise to check with people who have more experience to get information about moving forward. Maybe those people don't agree. Idk. I am not trying to be argumentative, I am genuinely trying to figure out how to make it work. Part of the fun for me is making it work from junk I can scavenge and have laying around. If I just want a set of loader arms to pick something up I would just go grab the skid steer and do it.
And yes, I realize the hand clutch will still be required. But riding the hand clutch and controlling a detent valve seems a whole lot more intuitive than riding a hand clutch forward and backward and the quadrant lever up and down, both at the same time. Its like trying to pat your head and rub your belly while trying not to crash into whatever you are trying to pick up or dump.
Edited by banjojelly - 26 Nov 2024 at 11:28pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 11:32pm
Originally posted by banjojelly banjojelly wrote:
I am only looking for help on how to put a valve block on it to bypass the lever. My hydraulic pump is strong, it is just the valving and lever that is worn/ broken...
I have never worked on a WD type hydraulic pump, so I just now spent five minutes perusing my I&J manual. That is one almighty confusing contraption! I certainly have more questions now than answers Tongue And I have done 'some' work with industrial hydraulics, both open and closed center stuff, etc.
I will make this statement: if you cannot explain how that thing works, it is probably best to leave it well enough alone. My late Father-in-law simply attached a 'normal' pump to the belt pulley drive on his WD, it worked fine.
Best wishes on your endeavors Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 11:37pm
Thank your for the lead on the video, that was very helpful.
Again, I am not looking for information on how to fix my linkage and valving to make the lever work. I could definitely go that route if I wanted to. But..... I don't want to. I would like to try and put a spool valve on it.
I will not be buying a new one. I will be scavenging one from a parts machine. Finding double or triple valves is no problem, I have several. I will have to do some crawling in our machinery grave yard for a single. But I'm sure I will find one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 11:45pm
I agree, it is a strange set up. I will give them credit for trying something different.
I will respectfully disagree with your statement. The best way to figure out how it works is to work with it. Its not brain surgery, its a 600 dollar tractor. I don't need to fully understand the intricacy's of their pump blueprints in order to understand how hydraulic fluid makes a cylinder move. Heck I had to take two classes of fluid dynamics in college! I passed but man those were the worst grades I ever got in college.
What I am gathering through this is that most people must not know how it works so the answer is put back the way it was and leave it alone. haha.
Thank you much for the well wishes.
Edited by banjojelly - 26 Nov 2024 at 11:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 6:38am
2200-2400 psi has been an industry standard since 1960 for open-center type valves. The relief is built into the valve itself. If you have found something rated higher than that, go for it. The WD hyd pump isn't really designed to run for 8 hrs a day with the LIFT/LOWER lever up all the time, but you can do it Pump service life over time I would expect could be shortened.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 8:15am
Thanks. My tractor is used more like a forklift than a tractor at this point. It gets started and I move stuff around with it and then gets parked again. It runs for maybe an hour straight at a time at most.
Is there a port where a return line could be plumbed in order to have a fluid return for lowering the loader? On lots of other older tractors, the hydraulic oil is in the transmission and it is easy to do, but on an AC I am pretty sure the transmission and hydraulic sump are separate. I may be incorrect though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 8:57am
 ... The best way to figure out how it works is to work with it. Its not brain surgery,..
Indeed.
Since I am an actual (retired) Bio-Medical Engineer (working with medical equipment that brain surgeons use) my inclination is to first learn how it is supposed to work, then fix it.
...It either wants to be full pressure up, or drop...
It sounds to me like you have already figured out how it works; now just position the valve controls to send full pressure up all the time, weld it in place, run the outlet line to your 'new' control valve and from there to the cylinders, and dump the return into the fill hole. Simple.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 9:09am
youi need a valve with an OPEN CENTER... The pump can run continuous and will pump THRU THE VALVE back to the hydraulic case ( you will need a return hose).... You can get a single valve or double if you need two seperate "LIFT" systems ( like a dump bucket)... If all you need is the RAISE cylinders, then a single valve with OPEN CENTER will do the trick.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 9:14am
some external valves will be RAISE / HOLD / FLOAT.... others will be RAISE / HOLD / POWER DOWN ....... if you get the POWER DOWN valve, you will need to route that hose back to sump... If you havae the FLOAT valve, with open center, your OK.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 9:26am
Benefits:
  • 1 Spool valve with compact design allows for installations in tight areas
  • All spools are standard double acting with spring return to neutral position which are ideal for double acting cylinders
  • Used for open center systems (Pump to Tank Flow) – closed center option available
  • Anti-drop load checks on each spool
  • Precision ground and hard chrome-plated spools assure a long life
  • High-tensile strength cast iron monoblock construction
  • SAE O-Ring ports ensure solid seal and prevent blockages
  • Capable of closed center or Power Beyond (conversion plug required)
  • Vertical or horizontal handle mount
  • Adjustable Relief Valve Range:  1500 to 3625 PSI
  • Preset Pressure Relief: 2610 PSI
  • Used as motor or single-acting spool possible (#8 SAE port plug required)
  Features:
  • Max Operating Pressure: P = 3625 PSI, T = 725 PSI, A & B = 4350 PSI
  • Flow Rating: 11 GPM (40 l/min)
  • A & B Work Ports:  #8 SAE O-Ring (3/4”-16) Thread
  • Inlet Port: #10 SAE O-Ring (7/8”-14) Thread
  • Outlet Port: #10 SAE O-Ring (7/8”-14) Thread
Edited by steve(ill) - 27 Nov 2024 at 9:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 9:53am
Indeed.
Ah. Yes, engineers have a different view than fabricators. Engineers design first, build second. Fabricators tend to design and build as the same process. I would put myself fully in the second category.
As for the second part, can I run the return straight back into the fill hole? I would think the system would have to vent somewhere. I am 100% willing to try it, just like to have a good idea of how it needs to work going forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 9:56am
Benefits:
  Features:
Thank you sir. The information from your posts is very much appreciated. I am starting to get a good picture of how I can make this work.
Would you happen to know where the return could be run to on the pump housing or transmission to get it into the sump?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 10:02am
Remove the drain plug to the hydraulic sump, install a tee, return oil into the side of the tee and still have a drain plug on the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 10:24am
Yup.
Before I switched careers I worked in sawmill maintenance for 30 years as a saw filer. I have a fair amount of experience from both perspectives
...As for the second part, can I run the return straight back into the fill hole? ...
Yes.
But Dr Allis' suggestion is better, and Steve has the correct valve configurations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 10:33am
This is a great idea. Thank you. I was thinking I would need to go in from the top. I was not thinking about the drain plug being an option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote banjojelly Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 10:39am
I appreciate all the insight. I am getting a pretty good picture in my mind of how to put a system together. I am thinking I may just build a set of forks for it while I am at it and remove the bucket. I do not have tilt cylinders, but I think I can easily control the fork tilt with a cheap #3500 electric winch. I am usually only picking up car and truck parts with it or moving small logs and trees. Anything too heavy and my steering goes away real fast.
