185 Bell housing?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Topic: 185 Bell housing?
    Posted: 20 Nov 2024 at 2:54pm
Would a 185 bell housing pattern match a 262 cu. in. from a Gleaner? The 185 engine is seized and needs to be replaced. Thanks to those 'in the know'.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 4:06pm
thats one giant step backwards  i would look for  another 301 with money for the 262 for some one working on a d series
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 5:35pm
     I would go along with that. Look for a 301 like he said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 11:03pm
While I appreciate your words of wisdom the question still remains wether the two have the same bolt pattern?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 6:05am
It has been a very long time since I was up inside the engine bay on a Gleaner C-2 or model F. I think if the engine is equipped with a cast iron tail shaft housing, I'd say no. I just don't remember that backplate as being tractor friendly. If the combine engine backplate has those large 3/4" holes for the tractor side frames, then yes, I think it can be made work.
