pto driveshaft 7000
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Topic: pto driveshaft 7000
    Posted: 11 Nov 2024 at 7:30pm
Looking for pto driveshaft from pressure plate to pto input.   70260565
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 9:42pm
Year ago, there was a clutch rebuilder from NW Iowa,called BMD. I think High Capacity bought them out. They would take your shaft, cut off the splines and weld on new splines for a Farmall tractor like a 966 that also had a 12 inch clutch. They would rebuild the A-C pressure plate and replace the drive hub with a Farmall hub to match the shaft they repaired. Maybe call them and see what they can do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 6:13am
I am pretty sure reliance bought them out and shut them down..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 6:16am
All States as a rebuilt shaft listed
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 10:14pm
I am pretty sure BMD was bought out by A&I. BMD was my go to supplier for clutch and TA parts from the time I started in 1976 until they were sold to A&I. At BMD I always talked to a gal named Mary and I remember occasionally talking to her at A&I after they were bought out. I am sure if she answered the phone tomorrow, I would recognize her voice instantly and it has probably been 20 years since I last talked to her.
There was a thread on the Red Power site a couple years ago that discussed the history of the various clutch and TA rebuilders that traced there roots to Bobs Grinding in north central Iowa.
This page was generated in 0.056 seconds.
