7000 engine change out
Lab Rat 67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lab Rat 67 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 engine change out
    Posted: 11 Nov 2024 at 4:11pm
I have a maroon belly 7000 and when I bought it I couldn't hear the engine knock. Bad on me. Pretty sure I have a rod on its way out. I have another 301 from a combine to install. Does anyone have any tips for this? I've replaced the 426 on our 8050 but just wondered if it was similar. It looks straight forward but I've been here before. Thanks in advance.
Edited by Lab Rat 67 - 11 Nov 2024 at 4:13pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 6:55pm
Before you go too far, confirm what that ‘knock’ really is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lab Rat 67 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 7:17pm
It's running 10-15 pounds of oil pressure. Knocks when there is no load and at idle. It's not the front pulley. I can drop the pan and check bearings but I think it's on it's way out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 8:17pm
Check the oil, make it’s not diluted with diesel fuel. 10-15 lbs cold idle? Hot wide open? Check the quality of the diesel, old crappy fuel can do weird things to a running engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lab Rat 67 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 7:41am
Oil is good. No diesel in it. Fuel is fresh but I'll go thru it and double check. 15 lbs of pressure hot 2200 rpm. If it had 25 at 2200 I'd be more comfortable although that's kinda low too. I'll pull it out of the shop and let it warm up and see if I can find where the knock is coming from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 9:04am
Just for giggles, toss some ‘fuel dryer’ in the tank.
As long as your at it, change the oil & filter, use a name brand straight 30 weight(for diesels), see how the oil pressure holds up.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 9:54am
If it's knocking, quit running it and drop the pan to see what is wrong. Keep running it, you'll have an air cooled engine with a rod hanging out the side, you'll then know exactly which one wanted out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lab Rat 67 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 10:14am
Funny. Trying to avoid that! It's a tractor I didn't really need but got it for raking hay. Now I'm questioning my decision. When I bought it it came with a spare motor but I don't relish swapping them out. It's a lot of work
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 7:01pm
The combine engine swap will require the change out of the front covers and dealing with the cam. Either pull the gear or lay it on the side and pull the rocker arms ( you can tie up the lifters if you have the proper dowels. ) pullng the cam.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 7:56am
Lots of variations in the 301 combine engines. Different heads, water pumps, oil coolers,injection pumps, turbo or non turbo, oil pumps, etc etc etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lab Rat 67 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 9:09am
So I'd have to pull the cam? I thought the gear would bolt up on the front cover. Everything else looks the same. Same turbo but different pump. I may be plastigauging my bearings to see what I can live with.   All great info from everyone. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 10:29am
If you have a rod knocking, you won't need to plastigauge it, just grab them and wiggle them, it's probably blued also. It could have a scored piston knocking though. That's much easier to fix than a spun bearing or thrown rod. The cam gear is a heavy press fit to the cam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 10:33am
There is a thread on the "Knowledge" section on this. It ain't near as easy as itseems.
