anybody have a rule of thumb
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: anybody have a rule of thumb
    Posted: 11 Nov 2024 at 2:05pm
for required HP for a given hydraulic pump?
For instance, what would a 2500psi 12gal/min pump require?
Edited by LouSWPA - 11 Nov 2024 at 2:06pm
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 3:18pm
http://www.metaris.com/hp-calculator.php
17.503 per the above calculator...Wink
Edited by DiyDave - 11 Nov 2024 at 3:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 4:49pm
Thanks Dave!
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 11:02am
Upsize Lou. Need 50 horse
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 11:44am
ROT......  you'll need 7 more HP than you've got Wink
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 7:41pm
Not sure what hydraulic suppliers still have charts for that kind of thing. a decade ago Baum Hydraulics , Omaha, Ne. had a chart in their catalog online. Listed gear, vane, piston/ open & closed center pumps. I'm sure there's still a company with a similar online chart. They also had chart showing how much PSI and piston diameter of cylinder to lift "X" pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 9:27pm
When would a hydraulic system ever be operated at full 2500 psi continuously ??  A series four D-17 hydraulic system not doing any work and engine running wide open throttle takes less than 1 HP to circulate 12 GPM of oil at 100 psi.   When you hit the end of a hydraulic cylinders stroke and don't let the hyd lever cancel to HOLD, the relief valve opens (2,200 psi takes 15 HP) and then makes the engine labor. So it's only a momentary 15 HP load.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 9:41pm
0.06 x Horse Power = GPH     [approximately]
Edited by Clay - 12 Nov 2024 at 9:44pm
