7045 And The Range Lever
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 7045 And The Range Lever
    Posted: 09 Nov 2024 at 9:49am
She has high and low, but she won’t go into park. Any ideas where to start looking?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 9:54am
The short park cable needs adjusted or replaced. It is adjustable at both ends. One inside the console. The other under the floor. Mine also had a loose bracket attaching the cable to the transmission.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 1:13pm
If it's the same as in 8050 it's possible that the end of the cable came out of the keeper on top of the transmission, that happened to me. I pulled the inspection cover inside the cab above the transmission and found that the wire clip had rusted and the cable was not in the keeper for the park lever, not an expensive fix but more of a pain in the butt fix.
Leon B Mo
