Engine Clutch Shaft
Bradleytrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Topic: Engine Clutch Shaft
    Posted: 28 Oct 2024 at 9:28pm
Good Evening all. You all have seen me around and probably knew my dad (Don MO). Dad and I went on an adventure 5 or 6 years ago to find a model 33 corn picker. Found a complete one on a Early WD SN#66181. The problem with the tractor is on the transmission housing, where the hand clutch pivot pin goes in the side of the housing, is cracked and broke out.
Dad and I came to agreeance that I should just get the tractor running and check for operation of the corn picker. Which we did. Picked corn with the corn picker. Had to ride the hand clutch because tractor was going to fast in 1st gear in good heavy corn. Dad made the recommendation to put a WD 45 diesel rear end in the tractor to slow it down.
Fast forward. Dad has since past away. I got all of his "treasures" and in all the parts I have a WD45D rear end and transmission that's in damn good shape. Serial # of diesel rear end is 230882D.
This summer I took the corn picker off the WD tractor. Started to tear the tractor down to restore it and replace the rear end and transmission with the diesel rear end and transmission. Since I have tore it down to absolutely nothing but a pile of parts in the floor, I gutted the torque tube on the #66181 tractor. After spending time on the AGCO website parts manuals and talking to the local AGCO dealer, We are in agreeance that serial number 70966 and prior uses a different seal configuration to separate the hydraulic cavity from the hand clutch cavity.
My reasoning for all this I think I can use the the engine clutch shaft out of the serial number 66181 in the 230882d torqued tube. I don't have the engine clutch shaft out of 230882d torque tube or i would use it. According to the Parts books the torque tube has the same part number form cradle to grave on the WD series tractors. And the engine clutch shaft has the same part number cradle to grave on the WD series tractors.
I have pressed the old seal bushing/sleeve off the engine clutch shaft from the 66181 tractor. I have since installed it into the 230882 torque tube. I have found no reason it wont fit or work. took a set of depth micrometers an measured the depth of the two seal lips where they would ride on the engine clutch shaft and it should work.
What is the difference in the torque tubes between the two and would there be any difference between the engine clutch shafts between the serial numbers? The parts books sure don't show one. Any and all advise is welcome. If dad (Don MO) was here, he could tell me in a second.
Thanks Bobby
1 WD45D, 1 A2 GLEANER, Wd w 33mounted corn picker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 2:09am
Hey Bobby, I again express my sympathies on the passing of your wonderful father.  He is truly missed on this forum.  All his knowledge.......alas, we have to go on and find the answers ourselves.
I can't help you with this one but I know a few of the guys on here who will.  e.g. DrAllis tbran and a few others.  They'll get around to this thread and help you out.  One thing I learned from your dad,,,,,,,have patience.. it'll come.
GREAT to hear from you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 6:55am
my 45 had a one piece two lip seal originally. Now you use 2 identical seals back to back. Could it be something like that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 7:16am
Never done one, but the "fix" was dual seals opposite each other, but also I think a sleeve driven onto the clutch shaft for the two seals to rub against.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 7:30am
....and like doc says it uses a sleeve on shaft. Did the original WD not use a sleeve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 8:28am
It appears the original single seal ran against the clutch shaft. The dual seal update was sold as a "KIT", which includes everything needed to get the improved parts in the same space. Remember, they were working with an area made for a single seal, probably 3/8" wide or less. It sounds like your s/n 66181 has already been repaired and updated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 9:05am
Was there a part number for the kit including sleeve
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 9:19am
70225869 kit
