Allis chalmers wd45 head gasket
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers wd45 head gasket
    Posted: 26 Oct 2024 at 12:56pm
I am replacing the head gasket on my wd45 and was wondering how difficult it will be.
I'm planning on leaving everything bolted to the head and only replacing the head gasket and valve cover gasket
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 1:12pm
I'm not planning on replacing the head bolts
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 1:52pm
I think you will have to remove the rocker arm assembly to gain access to some of the head bolts. Not much of a job at all. You'll have to readjust the valves when you're done anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 2:06pm
How hard is it to readjust the valves
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 3:36pm
My head gasket has been bad for a while and I'm just now realizing.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 4:21pm
I was able to readjust the valves and i am a moron. Just ask my dog
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 4:57pm
What do I have to do to readjust the valves
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:02pm
Its like any any valve adjustment. Clearance guide and a little patience. Instructions in the owners manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:05pm
In all honesty, if you organize the push rods by placing them in a piece of cardboard with 8 holes in it, and place them back EXACTLY where they were before you took it apart, the engine will run fine. This is because the valve lash really doesn't change just by replacing the head gasket. A new gasket or an old gasket are the SAME thickness. This isn't the best scenario, but someone who doesn't know how to adjust valves, this is the best way. The million dollar question would be WHY do you think the head gasket it bad and in need of replacement ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:12pm
My oil is full of coolant and water
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:21pm
Before you even think about removing the head, remove the oil pan and pressurize the cooling system (radiator). This will allow you to see where the coolant is coming from that is contaminating your oil.
The 201 or 226 engines are not known for head gasket problems. I doubt the head gasket is your problem. It is more likely an O ring on one of the sleeves, a hole in a sleeve or possibly a cracked head.
Edited by WF owner - 26 Oct 2024 at 5:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:28pm
It runs perfectly fine with the water oil mix.
This tractor sat outside uncovered for 15 years
Edited by hunter321 - 26 Oct 2024 at 5:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:30pm
How would I pressurize the radiator
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:36pm
I know the head is not cracked
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:46pm
No, you don't. Are there any frost plugs under the valve cover that are rusted out or pushed up out of place ?? My money is that or a cracked/split BLOCK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:49pm
You should be able to rent a pressurizing kit from a local auto parts store or buy an inexpensive one from Harbor Freight.
If you are sure the head is not cracked, I assume you had it off. Did you use any sealant on the head gasket when reinstalling? Have you retorqued the head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 5:56pm
It didn't look like any frost plugs are rusted or out
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 6:25pm
Before we do any major tests we are going to put used engine oil in and put everything back together and add head gasket sealer to see what that does
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 6:33pm
" My oil is full of COOLANT and WATER."     This is a confusing statement. Water and antifreeze (coolant) actually mix together. They do not stay separated.  WATER comes from rain water from the exhaust system not being adequately covered or sealed up when sitting outdoors. COOLANT (anti-freeze) comes from the engines cooling system having an internal leak.....rusted out freeze plugs in the cylinder head, a leaking head gasket (usually not likely) leaking sleeve Orings (again not normally likely) and a cracked block on the bottom, which is very likely. Remove the oil pan. Make sure the cooling system is full and pressure test the cooling system by pumping it up to no more than 10 psi and wait and see where the COOLANT starts dripping from. It may take a day or more to see any drips if it is a slow/small  leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 7:23pm
To check for holes we are going to fill the radiator with water and leave the oil plug out and if it drains the radiator we are going to wait and have a shop work on it
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 6:26am
You need to re-read and DIGEST what DrAllis is saying here. Simply leaving water in the rad won't show up the leak unless it's really, REALLY, bad. It needs a pressure test in order to show it up & even then it can take a couple of days to see anything.
Firstly though, if it's plain water in the pan NOT coolant (and assuming the rad has coolant) then I'd be tempted to replace the oil & run it a while to see if it's not just rainwater from standing outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 7:22am
I have (often) seen the outside where they looked fine, but the inside was badly corroded and they were leaking.
Pressurizing the cooling system is quite easy and it will show where the leak is coming from. Right now, you are guessing where it MIGHT be coming from.
I don't mean to be rude, but it seems like you are asking for advice but planning to ignore it. There is a lot of experience on this forum. If you aren't going to listen to the advice we are giving, you are wasting our (and your) time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 3:47pm
Is there any way to pressurize the radiator without the special tool. I can't get one right now.
I'm not trying to waste your time, I was hoping that I would not have to buy all new gaskets again. The oil has antifreeze in it.
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 3:59pm
Sometimes, local auto parts stores (like NAPA, Autozone, Advance Auto Parts, Pep Boys, O'Reilly's, etc. ) will "loan" specialty tools like a pressurizing kit. You pay for the kit, use it and return it for a full refund.
In my opinion, that will be (by far) your best first step. It's pretty hard to fix something when you aren't sure what the problem is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 4:10pm
I will try to get a pressure tester. How will I know what the problem is, where will it leak for each possiblity. How would I know if it is a head gasket
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 4:14pm
Remove the oil pan, top off the coolant and pressurize the system. Put a clean piece of cardboard under the tractor.  Find out where the coolant is dripping (maybe very slightly). Then take a good light and try to trace where the coolant is coming from.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 9:49pm
Do you have anyone in the area that would coach you a bit? Many people are willing to help if you are willing to learn. Maybe trade some labour for some coaching. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 10:08pm
I just get the feeling we aren't getting a fully accurate story.  The first post says " I'm replacing the head gasket and wonder how difficult it will be".  The next post says "I'm not replacing any head bolts".    As I read along, I'm beginning to think the head gasket has already been replaced and there is still a problem. Maybe not. Maybe the explanation is just poorly written. It would have been nice to know if this is a tractor that has been sitting for 15 years out in the wide open spaces without a juice can on the muffler and they just now have gotten it running, OR it's been running for quite some time and in the past had been sitting outside for 15 years, which really doesn't make any difference now. And the "I know the head isn't cracked" statement. How do you KNOW that?? unless you already had the head removed and magnafluxed for cracks ??? by a machine shop???
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 10:17pm
Sorry for all the confusion
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 10:18pm
Yeah, but you haven't cleared anything up either. How EXACTLY does the story go ???
