185 3pt lift capacity?
Wes(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Topic: 185 3pt lift capacity?
    Posted: 24 Oct 2024 at 10:04am
Hey guys, this is something I've not really considered before, but am looking at a 3pt tedder and want to use the 185.  Was told the tedder weighs 2000lbs.  I think it'll be fine, have fluid in front tires, no cast up front.  Looked at the dealer literature from when the tractor was bought new, and it doesnt say..   thanks, Wes
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 4:38pm
I believe the tractor will pickup more on 3 pt. than that. A lot depends on how far back from lower lift arm pins it's weight is. You may be looking for front weights if it sits back to far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 6:20pm
The lifting capacity in those days was never rated to my knowledge. I guarantee a healthy hydraulic system can lift enough weight on the 3-point to lift the front wheels off the ground and probably even with 500 lbs of suitcase weights installed. These tractors have been used for decades hauling large round balers on the 3-point hitch, but I'd always assume there were front weights involved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 6:33pm
Have a 3008 Bush Hog 3Pt Mounted on my 180D, HAD to ADD a Loader for ballast to keep front end on the ground as the 3Pt will lift whatever is put on it.  The BH weighs 1850lbs.
Edited by DMiller - 24 Oct 2024 at 6:33pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 10:01pm
This Escort weighed more than 2000 pounds
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 2:50am
The lifting capacity of 160 is 2000 Kg ( 4400 lbs) .
For the 200 it is 2090Kg (  4600 lbs)
I have no data for the 185
Edited by John426 - 25 Oct 2024 at 2:52am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 6:50am
It'll lift more than than the front end can keep down unless it has a loader
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 11:24pm
Update: it lifts the tedder with ease!  I can feel the frontend is light.  Haven't gotten it in the field yet.  Have weights that came off the rear axle on F2, just need a weight bracket to put them on this tractor, and it should help a bunch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 9:10pm
Here it is!  I've never really been able to post pictures, but I think I've got it now..
This page was generated in 0.069 seconds.
