Agco allis 9695 error code
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Agco allis 9695 error code
    Posted: 24 Oct 2024 at 9:19am
Transmission code E15. Manual says transmission coil temperature low 10f or below. It comes up at all temperatures but doesn't affect anything just has the alarm going off. What coil would it be referring to? Dealer hasn't been able to answer the question.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 6:39pm
Error code E15 can happen when coil MC1 is cold,below 10°. Or,the sensor input line is shorted to+12 VDC. Or, the sensor input line is open. When looking at the valve body, where the coils are attached, MC1 is the third from the bottom on the front row of coils.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 7:16pm
The actual transmission oil temperature sensor is located on or near the transmission oil filter head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 11:23am
Thanks, I will look into it when I have time.
