WD45 PTO drain vs torque tube drain |
FireMedic
Joined: 07 Oct 2024 Location: Minburn, Iowa Points: 10 |
Topic: WD45 PTO drain vs torque tube drainPosted: 17 Oct 2024 at 9:47am |
Checking all the fluids in my tractor. The drain to the PTO released light brown compromised oil. The drain directly forward of that PTO drain (at the torque tube) looks like perfect oil. Is there a seal between these two compartments? If so, where are the most likely points that I’m getting contamination of the fluid in my PTO? I would’ve expected both of these to be transmission based and share fluid.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88636 |
Posted: 17 Oct 2024 at 10:01am |
