Dupont paint question
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Topic: Dupont paint question
    Posted: 04 Nov 2010 at 7:41pm
Anyone here have any experience with Variprime and Chomapremier primer?  Pros/cons/recommendations?
Thanks in advance,
Thanks
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 8:00pm
Variprime is a good product, excellant over new bare or sandblasted metal. I have no experience with  the chroma line, can't offer advice there.
Toscani SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani SD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 9:25pm
vari prime is good on sheet metal,but is not really recommended for sand blated parts,it doesn't seep down into the porus blasted areas,epoxy would be better there,i have used chroma premier paints,witch are very high end paints,but not the primers,u really don't need a fancy primer like that when the cheaper ones will give the same results
